The Skywatcher Star Adventurer equatorial mount is a lightweight portable tracker that is generally used for wide field astrophotography. I have been trying to see how far it can be pushed for astrophotography of deep space objects. My aim has been to get small, well resolved, round stars while using a camera and lens system that has a plate scale of as low as 1.6 arcseconds / pixel [Nikon J5 camera with a 20MP 1-inch sensor, 300mm PF f/4 lens (7.5cm max aperture)]. To put 1.6 arcseconds / pixel in context: atmospheric turbulence usually blurs objects by about 2 arcseconds; the diffraction Airy disc for a 7.5cm aperture is 3 arcseconds. The target was M13, since the tight cluster of stars is a real challenge to resolve.
To maximise the chances of getting round stars I have a system that minimises the load on the tracker. All the equipment on the Star Adventurer mount comes to just 3.5kg (camera, lens and hood, red dot finder, guide camera and scope, ball head, declination assembly, counterweight). The Star Adventurer wedge is mounted on a Berlebach Report 112 photo tripod.
Guiding was with a ZWO ASI 120MM Mini USB 2.0 Mono camera and a ZWO mini guide scope (30mm diameter, 120mm focal length).
Polar alignment was done initially with the polar scope on the Star Adventurer, then refined with the drift alignment utility on PHD2 guiding software. Once aligned, the declination drift rate averaged 1.4 arcseconds/minute, i.e. less than 0.5 pixel for a 30s exposure on the imaging camera.
During 2 hours of guiding PHD2 reported a typical RA error of 2 arcseconds. 187 30s images were captured.
Raw files were cropped and converted to tiff files. The best 15 files were stacked in deepskystacker. Final processing was done in lightroom.
M13 - Hercules globular cluster. Field of View = 1.1 degrees. Best viewed at 100%.
To my eyes, the faint stars look round (with a minimum diameter of about 3 pixels or 5 arcseconds), and those which are 7 arcseconds or more apart seem readily distinguishable. Bright stars show some slight distortions / edge effects. Overall, I’m very pleased with the result. My conclusion is that the Star Adventurer can do a fine job even with a system with a plate scale of 1.6 arcseconds / pixel.
Andy
Andy
