Sailor Blue
A fuller review is available on Dropbox.
Sailorblue - Review of Selens 65cm 26" Foldable Collapsible Beauty Dish Softbox & Honeycomb Grid Flash
A few days ago I received a new Selens Foldable Beauty Dish Softbox. I didn’t expect it to be a beauty dish, and it isn’t, but it is a nice foldable 16-sided umbrella softbox, a hexadecabox. The softbox comes with inner and outer diffusers, a grid, and a fabric bag that will be good for storage and transport.
The black fabric of the softbox is thin and coated with shiny aluminum. Even though the fabric is thin it is of seemingly good quality and the stitching is of very good quality. I would have preferred it if the fabric had been a bit sturdier but since I won’t be assembling/disassembling the umbrella frequently it should last me for a long time.
There is a 2” wide strip of black Velcro sewn inside the rim of the umbrella to hold the outer diffuser and grid. There are 16 white Velcro tabs about 5” inside the umbrella to attach the inner diffuser.
There are four Velcro closed tabs at the back of the umbrella to allow you to tighten it around the speedring. In reality these tabs don’t seal the umbrella to the speedring tightly and have no other necessary use.
The umbrella comes with a Bowens speedring so I also bought a Godox S-Type Bowens Mount to allow me to use the new softbox with my Nissin Di866 Pro hot-shoe flash.
The wide angle Light Diffusing Panel of my Nissin Di866 Pro hot-shoe flash gives it coverage equivalent to a lens with a focal length of 18mm. I found using it improved the distribution of light across the outer diffuser without effecting the light output significantly so I used it for all the tests below.
All tests were done with the softbox at 1 diameter, 26”, from the wall.
I started with the grid in place. The grid uses about 1-½” of the 2” of black Velcro inside the lip of the umbrella. The remaining ½” is used by the outer diffuser.
From the piece of blue tape in the center of the disk of light to the first piece above it the light drops off by 1.0 stop. The light level at the top piece of tape is down by another 0.7 stops.
I like the well defined disk of light from the softbox but the light escaping between the back of the umbrella and the speed ring is casting stray light on the wall outside the disk of light from the softbox. I couldn’t eliminate this stray light by tightening the Velcro tabs at the back of the umbrella as much as possible. I could have draped a piece of black cloth across the back to get rid of the stray light but this shouldn’t be necessary.
I then removed the grid so show what the light pattern was with the double diffused softbox.
Tests without the outer diffuser and without any diffuser showed a hot-shot in the center, not an umbra/penumbra of a beauty dish.
In summary the Selens 65cm 26” Foldable Collapsible Beauty Dish Softbox & Honeycomb Grid Flash is a nice compact and easy to transport hexadecabox but it is definitely not a beauty dish.
The construction quality seems to be good and the light pattern is as expected. I will be using it in the double diffused or double diffused and gridded configurations. Because the hexadecabox is nearly round the light pattern is round and the catchlight should be nearly round as well.
The softbox fabric is very thin but only time will tell how well it holds up.
I did find two negatives. You can’t reach the locking mechanism of the softbox from the rear so you have to partially or wholly remove both diffusers to reach it when opening or closing the umbrella. The fit of the back of the umbrella to the speedring should be better to reduce the stray light produced.
Living and loving it in Pattaya, Thailand. Canon 7D - See the gear list for the rest.
