Rol Lei Nut
I think nobody has seriously wanted to shoot wildlife with a rangefinder camera since around 1959...Thanks, I've read about. Obviously the main technical difference to the otherwise more or less identical Bessa. I never looked more detailed into the ZI specs as I never wanted to spend that much for a toy with limited possibilities. Therefore I only have a couple of Russian Leica copies and the Bessa R2.The ZI has a much wider effective rangefinder base than the Bessa. That means more accurate focus, especially with longer lenses.
On the other hand I wouldn't recommend to shoot wild animals or similar objects with a RF camera unless you have an accessory such as the Leica Visoflex system. Luckily my longer Leitz lenses such as the 90mm Elmarit and the 135mm Elmar are Visoflex compatible (detachable lens heads which are also very useful to turn these lenses into very capable macro ones) and my longer Telyts (200 and 280mm) are designed as Visoflex lenses anyway. BTW, Visoflex is usable on the Bessa as well, although I have to admit that I never tried it in real practice as I prefer to shoot digital for such tasks; i.e. with my longer RF lenses anyway. It's in any case a rather cumbersome process to use longer lenses on RF cameras.
Even the best and most modern RF cameras have still some limitations. That's a matter of fact.
I'm using my Bessa primarily with wide angles to make use of the wider angle of view compared to my digital APS-C camera. The CV 12 and 15mm lenses really look more spectacular on the bigger film format and there is no problem with color shift or alike on film. Consequently I didn't really care about the accuracy of the focus system of the Bessa when I made my decision for purchase. Most probably even the finderless L version would have been good enough for me. ;-)
I do hope that this clarifies my point of view which is obviously slightly different.....
Photographers who love rangefinders know their limits and qualities quite well.
Accurate focus is important, hence the preference for decently specified rangefinder bases.
