Came across a more recent Guide today. 2016. Page 5 has some interesting info.
First time I have seen Canon mention the light source. I use FoCal and there are instructions not to use fluorescent or any source that flickers but not temperature. Since I use my 100-400 II outdoors 90% of time I purchased two studio daylight balanced CFL's to light the target. I turn other close light sources off try to put the target close to a window if sunny. It is mentioned that incandescent will work and it does but I figured I may as go all the way and they aren't that expensive.
If anyone is interested I found this a while ago. You can get them at Home Depot, etc.
www.scientificamerican.com
The first time I have seen Canon combine your usual shooting distance and 50X.
You can download the PDF from here.
Flickering Fallacy: The Myth of Compact Fluorescent Lightbulb Headaches
Does the flickering of CFL bulbs cause headaches?
