User5511277733
Active member
So I was taking some test shots and realized that for repeat-ability I should probably tripod mount and then use a remote to pull me out of the equation...and I noticed some oddly OOF images. If I "pre-focus" by half depressing the shutter, they're fine.
So I did some reading, looked at Nikon's website for the functioning of the ML-L3 and it seems to state that I should have no issues as long as I am in AF-S / S. So I tried that and no change. I cycled through all the options for both AF-S and AF-C and none of them would change the focus distance. I did not check the camera release button on all settings, but anytime I directly interacted with the body and half depressed the button my camera had no issue with immediately focusing.
I thoroughly tested all options with my Sigma 17-50 2.8 @ F2.8. I did some other tests with my Tamron 12-24 F4, Sigma 85 1.4 and Sigma 50-150 2.8. All wide open, all center point. Moderately lit room by both sunlight and multiple bulbs. Shutter speeds were around 40 - 60 for the 2.8 and ISO was at 100. Battery was fully charged and only has my test photos on it. I've tried immediate as well as 2 second delay for the remote with no change in performance.
Again, there are no issues at all with manually using the camera. It is only an issue when I try to use the remote.
