Godox V860IIs or TT350s
Started Apr 11, 2017 | Discussions
WhiteVsBlack New Member • Posts: 2
Maybe question will be stupi, but:
V860II - GN60/ISO100-200mm
TT350 - GN36/ISO100-105mm
I want to know GN=?, V860II/ISO100-105mm
If the difference will be small I don't see the point to buy more expensive 860II
Don't know how to calculate it.
Or maybe other propositions for sony A7II? TTL+HSS is a must have.
Casio Exilim EX-V8 Sony a7
kli
kli Veteran Member • Posts: 4,587
Re: Godox V860IIs or TT350s
You're misreading a bit.
The guide number is given as a distance; so whether it's in feet or meters matters. And that distance is for the flash at a given combination of zoom setting and ISO setting when used at full power. If you take the guide number and divide it by the f-number of the aperture setting you're using, that's how far away a subject can be and still be properly illuminated by the flash.
Given that they're going with lowest iso, highest zoom, and highest power setting, this is the absolute limit of what your flash can do.
So, the numbers are:
V860II - GN 60m @ISO 100, zoom 200mm.
TT350 - GN 36m @ISO 100, zoom 105mm.
More realistically, it's probably going to be about half to two thirds that number in use, because you won't be zoomed in all the time. Zoom on a flash is basically how far forward/back the flash tube in the head is in order to control the spread of light. Zooming all the way in puts the tube all the way back to give the tightest, most focused beam possible, which looks the most powerful, so a lot of manufactures put the GN spec in that arena. In reality, at 35mm zoom, that V860II's guide number will probably be between 35-40 meters.
So, yes. This is a BIG difference.
The V860II is a full-sized speedlight, that runs off a Li-Ion battery pack with the capacity of roughly 3 sets of 4xAAs in it. The TT350 is a mini-flash for mirrorless that runs off 2xAA batteries. The V860II not only can pump out a lot more light per flash, but can do up to 600+ full power bursts off one pack before needing a new one, while the TT350 can only do about 200+ full power bursts before needing a new set of batteries. It's much less powerful.
And power with a flash is like max. aperture with a lens: the more you have, the more you can do.
Question is whether you plan to use the flash on-camera or off-camera and whether you just need it for fill or as your main source of illumination. On-camera, a big full-sized flash is likely to be unwieldy and top-heavy. A smaller unit is likely to balance better.
The other TTL/HSS main contender for Sony mirrorless would probably be the Nissin i60.
 kli's gear list:kli's gear list
Fujifilm X100T Canon EOS 5D Mark II Canon EOS 50D Panasonic Lumix DMC-GX7 Canon EF 135mm F2L USM +12 more
lehill
lehill Veteran Member • Posts: 7,118
Normally, there's a table way in the back of the flash owner's manual that gives GN vs zoom head position. This table should be used for authoritative guide numbers. I see that Godox doesn't include this table for either flash.
I used the table for my Sony flash (confirmed with a Canon flash table) and found GN varies approximately by the square root of zoom head position except at the widest zoom (when you use that flip-out screen). So:
GN(105mm, ISO100, V860II) ≈ 60m x (105/200)^0.5 = 43m +/-10%
If you'd like to confirm this approximate relationship, try downloading some Canon or Sony flash manuals.
Godox rates the V860II for 650 full-power flashes on a full charge, the TT350 for 210 full-power flashes. So you're buying a some more power & lot more flashes for your money.
Lance H
 lehill's gear list:lehill's gear list
Sony a6000 Sony a7 II Sony a99 II Sony a7R IV Sony a7R V +32 more
OP WhiteVsBlack New Member • Posts: 2
Thanks for your replies they are very helpful
I was digging about different flahes and i found manual for METZ 64 AF-1. It has almost the same zoom coverage as the V860II. At the end of that manual I found tables about ISO/Zoom/GN data.
Metz have got GN=64/ISO100,200mm, but more or less, now i have a clue how it looks like.
ISO/Zoom/GN
Zoom/GN in HSS mode
I know that that was obvious for me, GN=flash range at full power, or how else we can call it
