ARCA L bracket for GX8?
JimW-203
Well-known member
Tarpon Springs, FL, US
I often work with a tripod and miss the ease of moving from landscape to portrait. Since all my tripods have permanent ARCA adapters on their heads, I would prefer to change the orientation with the plate and not the head. Does anyone have suggestions for an L bracket that would fit the GX8 without negatively impacting camera operation. I realize battery/card access will probably be hindered.
A suggestion: go to local hardware store and buy a L bracket for a couple of £'s, then drill 2 holes where required. They always have loads of different angle brackets and you may even get one with the correct holes if you're lucky.
But if you need a posh purpose made bracket I have no idea. As I nearly always make my own bits.
