Jeff,
It's a wonderful lens, and quite sharp at any aperture. All of them are.
When I had my RX10m1, I did a sharpness shootout: R1, RX10m1, rx100m1
My conclusion was, forget about it, just use the settings needed for any shot, bingo.
Test your specific lens using Jpeg, don't let RAW software get involved.
I shoot my back fence: textured wood, lines, tops of pickets, ivy, vines, shadows, stuff behind, grass in front at base. IOW, check sharpness in a photo. I don't take photos of test charts, so why would I use one to prove something I may never see.
As others have noted, f5.6 with 1" sensor gives full focus depth for landscape shots, so higher f#s are only to cut the light for specific reasons, not sharpness.
I use wider apertures to allow faster shutter speeds or lower ISO most of the time. You will see ISO noise before you will see lack of sharpness, and that noise is everywhere, not some inconspicuous corner.
Elliott
