FaithfulCountryGirl
New member
- Messages
- 8
- Reaction score
- 0
I have a Nikon D4s and D810, and multiple Nikkor pro lenses. I'm a portrait and sports photographer and know the obvious troubleshooting steps for focus. But I've been experiencing an abnormal number of soft photos with both cameras for a long time now. Here are the facts/working conditions:
1. I'm using Single Point focus, with the focus point directly on the target. I'm not focus-recomposing. Just keeping the focal point on target.
2. My shutter speeds are more than adequate. Typically over 500 as I like to shoot candid portraits and want to freeze it. And definitely NOT motion blur.
3. My playback image and my focus-detection software both clearly indicated my focus point was in fact locked on target for the shot.
4. It's not an AF Fine Tune issue. Under controlled environments (testing focus on a stationary calibrating tool for example, or photos taken my studio under single-shot method are overall clear and sharp.) It's primarily out in the field that this happens.
5. When I shoot Sports it seems to be fine as I'm at a greater focal distance. The problem is very prominent when I shoot my portraits (which are typically at f2 -2.2, with 10-20 feet distance from subject). And particularly with my 85mm 1.4G and 50mm 1.4G lenses.
6. I've tried back button focus and standard shutter release focus, both with the same results.
7. I Prefer AF-C continuous. I'm used to it with sports, and so it's natural for me to use it in portrait sessions, again so I can catch the candid stuff when it happens. But knowing AF-S is more reliable at shallower DOF, I've done that too, with no improvement. My Focus Tracking is set to Normal.
I was utterly convinced that this was a hardware issue, though it has been very hard to trouble shoot given all the variables (multiple cameras, lenses, focus methods, etc). I've sent them all into Nikon for evaluation and everything checks out fine.
I've come to the realization that it's something I'm doing as these are obviously very good cameras and lenses and it's happening across the board. I have a feeling it has to do with my camera's ability to grab focus when shooting continuously at shorter ranges (even if I'm diligent about my focus points being on target). But I wonder if it's due to the way I depress the shutter or something?
Can someone please correct me if I'm wrong? I THOUGHT that under the conditions stated above. I should be able to pretty much hold down the shutter release (or AF-ON + Shutter, when I've got AF-On Only enabled) and fire away. But I'm not exaggerating when I say, probably only 20% of my images are tack sharp in any given sequence. In other words, same exact exposure settings and focus method, etc. in a sequence, and maybe 2 out of 10 are tack sharp.
Side note: What is a realistic expectation for percentage of sharp photos? nd by sharp, I mean TACK SHARP. With these camera bodies, I'm expecting about 85-90%. But maybe I'm being unrealistic.
What am I doing wrong? I'm so discouraged I want to just hang up my hat photographer
My website is www.ksetterfield.com as a general shooting style reference. Thank you in advance to those willing to help.
