Phathom
Not a Canon guy, but thought you guys might want to watch this.
I saw that too. It must be a mistake.Wait, I'm a little confused...at 5:55, he mentions that the 80D lacks the single point spot AF. At 8:10 though, he mentions single auto focus point...so what does the 80D lack exactly at 5:55?
Single point spot AF is a function the 7D has. The 70D and 80D have single point AF but not single point spot AF. Single point spot effectively gives you a smaller AF point useful in some hard to focus situations such as focusing on a bird between branches of a tree.
You're right. I've been considering the 6D since it came out but I'm more interested in APS-C at the moment,particularly in the 80D and the A6300, though my interest in the 80D is diminishing with each review I see. I may get both the 6D and A6300.Sounds like what you want is a 6D.
After my last response I was curious so I did a quick comparison of some test images from the 6D, 80D and A6300. I have to say, in those test shots, I find the IQ of the A6300 to be about the same as the Nikon D7200 and noticeably better than the 80D . In one set the IQ of A6300 was noticeably better at low ISOs than the 6D but on another set the 6D IQ was just a bit better. Of the cameras I just compared at higher ISOs, the 6D jumps ahead in noise handling followed by the D7200/A6300 (very close) and the 80D, in that order.I've used both the 6d and the 70d. I ended up selling both and getting the 80d and so far I am very pleased with the af, image quality and ease of use(as I had with the 70d). i really liked the iq of the the 6 but I found that when I was heading out, I always preferred to take the 70. Since I don't mind changing lenses and I have no need for a backup cam the 6d was just extra gear.
The 80, to me, is just a much improved 70 and I found little wrong with the 70.
Anyway, I hear the herons calling and I have to go.
What tests? High ISO? DR? Sharpness? Video Quality?After my last response I was curious so I did a quick comparison of some test images from the 6D, 80D and A6300. I have to say, in those test shots, I find the IQ of the A6300 to be noticeably better than the Canons.I've used both the 6d and the 70d. I ended up selling both and getting the 80d and so far I am very pleased with the af, image quality and ease of use(as I had with the 70d). i really liked the iq of the the 6 but I found that when I was heading out, I always preferred to take the 70. Since I don't mind changing lenses and I have no need for a backup cam the 6d was just extra gear.
Studio Setup IQ at DPR and IR at several ISOs ranging from low to high. Check them out for yourself, it doesn't take long.What tests? High ISO? DR? Sharpness? Video Quality?After my last response I was curious so I did a quick comparison of some test images from the 6D, 80D and A6300. I have to say, in those test shots, I find the IQ of the A6300 to be noticeably better than the Canons.I've used both the 6d and the 70d. I ended up selling both and getting the 80d and so far I am very pleased with the af, image quality and ease of use(as I had with the 70d). i really liked the iq of the the 6 but I found that when I was heading out, I always preferred to take the 70. Since I don't mind changing lenses and I have no need for a backup cam the 6d was just extra gear.
Ok, then take Canon 6D out of the equation ... is "noticeably" much better than A6300 at high ISOStudio Setup IQ at DPR and IR at several ISOs ranging from low to high. Check them out for yourself, it doesn't take long.What tests? High ISO? DR? Sharpness? Video Quality?After my last response I was curious so I did a quick comparison of some test images from the 6D, 80D and A6300. I have to say, in those test shots, I find the IQ of the A6300 to be noticeably better than the Canons.I've used both the 6d and the 70d. I ended up selling both and getting the 80d and so far I am very pleased with the af, image quality and ease of use(as I had with the 70d). i really liked the iq of the the 6 but I found that when I was heading out, I always preferred to take the 70. Since I don't mind changing lenses and I have no need for a backup cam the 6d was just extra gear.
As I said previously, I have no interest in video.
Advantage to those large photosites. I don't shoot much in the dark or at higher ISO but, if I felt the need, the 6D would be better for it with the penalty of a bit lower resolution.Ok, then take Canon 6D out of the equation ... is "noticeably" much better than A6300 at high ISOStudio Setup IQ at DPR and IR at several ISOs ranging from low to high. Check them out for yourself, it doesn't take long.What tests? High ISO? DR? Sharpness? Video Quality?After my last response I was curious so I did a quick comparison of some test images from the 6D, 80D and A6300. I have to say, in those test shots, I find the IQ of the A6300 to be noticeably better than the Canons.I've used both the 6d and the 70d. I ended up selling both and getting the 80d and so far I am very pleased with the af, image quality and ease of use(as I had with the 70d). i really liked the iq of the the 6 but I found that when I was heading out, I always preferred to take the 70. Since I don't mind changing lenses and I have no need for a backup cam the 6d was just extra gear.
As I said previously, I have no interest in video.![]()
The A6300 also has a weaker AA filter than the 80D so it's a bit sharper.A6300 has better IQ at high ISO than 80D but not by much. Canon 80D has more chroma noise which is very easy too remove.
I agree. The A6300 also has better DR at higher ISO according to the comparison chart at this site:In therms of DR, A6300 is better than 80D at ISO 100 by 0,66 - 1 stop, i would say.
interesting comparisons..Not a Canon guy, but thought you guys might want to watch this.
Just a lawyer who spends way too much time and money pretending to be a photographer.
http://500px.com/stephencorby
Correct me if I'm wrong, but doesn't the 80D gain the upper hand here in terms of dynamic range due to the new sensor?I was really interested in the image quality of the 80D vs the 7Dm2 but since it doesn't really seem to be much different, it will just come to what features you want.
