Brian Cruickshank
Active member
I have cross posted this on the Canon 5D forum since that's what the flash is paired with.
I am using my 600 EX-RT as a master to fire a 430EX slave in optical mode. Using the 600 EX, attached to a Canon 5D mk III, I can fire the 430EX and the 600 simultaneously with no problems. However no matter what I do, I cannot disable the master. I have tried to disable the master in two different ways, with the same result: Using the in-camera External Speedlight Contol, if I disable the master (icon indicates master is disabled), the master still fires. Alternatively, if I attempt to disable the master using the in-flash command (Menu 2) and the icon correctly says the master won't fire, it still does. In both cases, both the master and slave fire. Any ideas?
