Disappointed
Started Nov 14, 2014 | User reviews
js473 New Member • Posts: 10
Disappointed
I'm still a young photographer in the learning but one thing i can tell you is that this lens has been by far the worst i ave ever used.
-It has major issue focusing in low light, even sometimes during the day and 90% of the time the lens forever hunts just trying to acquire focus when zoomed in anywhere from 80 and upwards
-Picture quality is some what soft through out the range but thats to be expected from long range lens
-It suffers from zoom creep (zoom right in to 200mm point your lens upwards and just watch it slide back down on its own, zoom out to 18mm and point downwards and watch the lens barrel extend)
-Serious vignetting
However i mostly used this lens for landscape (thats what i find its only good for because the higher the focal length i go the more useless it becomes)
 js473's gear list:js473's gear list
Canon EOS 600D Canon EF 50mm F1.8 II Canon EF-S 18-200mm f/3.5-5.6 IS Samyang 8mm F3.5 Aspherical IF MC Fisheye Canon EF-S 55-250mm f/4-5.6 IS II
Lens • Canon EF-S • 2752B002
Announced: Aug 26, 2008
js473's score
1.0
Average community score
3.3
Jon_T
Jon_T Veteran Member • Posts: 6,407
Re: Disappointed
In regards to the 18-xxxmm zooms the Canon EF-S 18-200 IS is one of the better 18-xxxmm super/ vacation zooms.
The zoom creep, barrel distortion, CA (Chromatic Aberration) and vignetting are common with all 18-xxx super zooms in this price range. Another item is the full 200mm focal length is only at infinity. In order to facilitate the 17.7” close focusing, the focal length has to be reduced as the camera to subject distance is reduced.
Vignetting:
Are your referring to jpg images or RAW images? If jpg, do you have the camera's "Peripheral illumin. correct." enabled? To obtain the optimum image quality recommend shooting RAW (or JPG+RAW) and use Canon's DPP program that came with your Camera (CD) to easily correct the barrel distortion, CA (Chromatic Aberration)/ purple and vignetting in RAW images
AF Problems:
Which AF mode are you using -- All 9-points or the Single Center AF point?
Using the EF-S 18-200 IS on my 60D and 70D using the single Center AF point I have not experienced the extent of AF problems you're having. "Low light" is vague description to evaluate your problem. I have used the EF-S 18-200 @ 200mm (with mono pod) in lighting conditions at an event requiring ISO 3200 and shutter speeds around 1/60. Never experienced the AF "hunting" in daylight conditions, with 60D, T2i I had, or 70D using the single Center AF point.
Just a FYI I've had the Canon EF-S 18-200 IS for over two years. Bought the 60D with EF-S 18-200 IS Kit on sale at Costco.
Curious, did you read any reviews on the EF-S 18-200 IS prior to buying? All the super zooms need to be stopped downed 1 or 2 f/ stops from the max aperture value of the focal length being used. When I use the EF-S 18-200 for the one-lens convenience, I use the Av mode set to f/8 to get decent edge-to-edge sharpness.
See the SLRGear EF-s 18-200 IS Review and play around with the "Blur Index" interactive tool. Provides a 3-D visual of the edge-to-edge sharpness at different focal lengths and aperture combinations.
Several other EF-S 18-200 IS reviews:
http://www.lenstip.com/306.1-Lens_review-Canon_EF-S_18-200_mm_f_3.5-5.6_IS_Introduction.html
http://www.the-digital-picture.com/Reviews/Canon-EF-S-18-200mm-f-3.5-5.6-IS-Lens-Review.aspx
http://www.dpreview.com/lensreviews/canon_18-200_3p5-5p6_is_c16
FWIW some samples of my results with the EF-S 18-200 IS (all jpg images from camera):
200mm, 10' x 12' room illuminated with 200 watt bulb. Camera built-in flash -- did not use the AF flash assist -- no AF hunt. Hairs quite clear around nose/ mouth.
135mm ISO 1600 f/5.6 @ 1/30 hand held. Focused on the head of the guitar to get a mid-point focus between the two subjects. The "GUILD" on the guitar head is quite clear taking in consideration ISO 1600 noise and the 1/30 hand held.
Old 200mm @ f/11 Test shot I did
I like Roger Cicala's (LensRental.com) comment on super/ vacation type lenses:
Unfortunately, many people want “great image quality in one lens that will cover everything”. That’s a lot like having a bumper sticker that says “honk if you love peace and quiet”.
OP js473 New Member • Posts: 10
Re: Disappointed
vignetting:
i always shoot in raw and use photoshop cs6 for post. So correcting the vignetting, CA or distortion is not a problem however i find the canon ef-s 18-200 IS suffers from major vignetting on the longer focal end 100-200mm especially when decreasing fstop from f/11-f/22.
AF:
i tested all 9 points individually and all 9 together got the same results also it doesn't matter what ISO, f-stop or shutter speed i use, it could be hot sun outside using ISO 100, f/8, 1/640 when zoomed in to 80mm and upwards, 80%-90% of the times the lens hunt trying to acquire a focus point on the subject.
I don't even bother try anymore in poorly lit conditions because anywhere that requires me to use at least ISO 800 with that lens its a 100% guarantee than from 80mm and upwards, i would never get a focus lock on subject and from 18-70mm is a hit and miss (sometimes it locks no problem sometimes is doesn't)
I know vignetting, CA, distortion, zoom creep are all things super zoom lens suffer from but my major problem is the AF. It just totally sucks and i cant count the numerous times i missed 'that special moment' because of the lens forever hunting trying focus. Sometimes i had to resort to manual focus.
Could just be the model i have was from a bad batch - never know.
One thing i notice that i forgot to mention also is that with the recommended lens hood attached, the ends of it are visible in my frame when zoomed out at 18mm and disappears from the frame by 24mm.
Anyways i more use this lens for landscape now because its a total let down for me as a walk around lens
Tested on t3i and 60d
Genghis7777 Junior Member • Posts: 36
Re: Disappointed
Just been reading about your lens disassembly over here: http://www.dpreview.com/forums/post/57289931 . With hindsight, do you think it's possible that your AF problems might stem from the fungal issues within your lens?
 Genghis7777's gear list:Genghis7777's gear list
Canon PowerShot A530 Canon EOS 20D Canon EOS 60D Canon EF 50mm F1.8 II Canon EF-S 18-200mm f/3.5-5.6 IS +3 more
Dave
Dave Veteran Member • Posts: 6,231
Re: Disappointed
I'm curious how fungus entered the lens.
 Dave's gear list:Dave's gear list
Canon EOS 80D Canon EF 135mm F2L USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-300mm f/4-5.6L IS USM +10 more
RichGK Regular Member • Posts: 289
Re: Disappointed
Considering that you have the 55-250 which is a great lens why not sell the 18-200 and use the funds to purchase a normal zoom such as the Tamron 17-50 or Sigma 17-50? They are both excellent lenses and you'll have 17 to 250 covered albeit requiring lens swapping occasionally. You'll should even have a bit of change left over to add a polarizing filter.
I did the same as you and hoped that I could replace a few lenses with one all singing all dancing lens and not give anything up. What you give up is quality in large amounts!
 RichGK's gear list:RichGK's gear list
Canon EOS 5D Canon EOS 40D Canon EF 24mm f/2.8 Canon EF 70-200mm F4L USM Sigma 17-50mm F2.8 EX DC OS HSM
Mark B.
Mark B. Forum Pro • Posts: 29,756
Re: Disappointed
I'm curious why it's being asked a year and a half after the original post.
Dave
Re: Disappointed
Fair question. Because I didn't even know about this until Genghis7777 "excavated" the thread.
007peter
007peter Forum Pro • Posts: 12,933
Unfair Review - Criticizing "Super-Zoom" for lack of IQ. Nature of Beast
js473 wrote: I'm still a young photographer in the learning
Yes, that is obvious to us all
Its call a "Super-Zoom" for a reason. You gain increase focal range by sacrificing IQ, AF speed, etc...
Again, its a "Super-Zoom". That means it will have a horrible T-STOP (light transmission) due to numerous inner lens element blocking light transmission. Less light = more AF hunt. This should be obvious.
Yes, like you say, its expected to be poor
Can't be help. When you extending the lens that far from the body with a heavy front lens element, you will get zoom creep. This is call physics.
-Serious vignetting
What do you expect? Having that many inner lens element compromising optical transmission, you have less light and you will get "serious vignetting". All super-zoom suffer from this.
Canon 18-200mm IS USM is a super-zoom.  As such, what do you expect?
  • Do you blame a DOG for barking?
  • Do you blame a CAT for purring?
These are the nature of the beast, and for a Super-Zoom, slow AF, severe vignetting, and zoom creep are its nature.
If you want Great IQ, shoot PRIME!  A Single Focal Length lens that is optimized for IQ by sacrificing zoom range.  There is a reason why many of us (serious photogpaher) do not even consider buying a Super-Zoom.
 007peter's gear list:007peter's gear list
Panasonic Lumix DMC-GF6 Panasonic 20mm F1.7 II
ed rader Veteran Member • Posts: 9,068
thats like criticizing an f4 lens....
for "only being f4"
 ed rader's gear list:ed rader's gear list
Canon EOS 80D Canon EOS 5D Mark IV Sigma 15mm F2.8 EX DG Diagonal Fisheye Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +4 more
ttbek Veteran Member • Posts: 4,869
Re: Disappointed
Vignetting:
AF Problems:
_Unfortunately, many people want “great image quality in one lens that will cover everything”. That’s a lot like having a bumper sticker that says “honk if you love peace and quiet”.
Very true, but sometimes it seems like they're not even trying to make a good lens.... when they do try it costs around 78k and is a 20x zoom
 ttbek's gear list:ttbek's gear list
Canon PowerShot SX10 IS Canon EOS 5D Samsung NX300 Canon EOS Rebel SL1 Samsung NX30 +37 more
gavin
gavin Veteran Member • Posts: 8,242
Re: Disappointed
Sounds like it is working as expected for super zoom. You have traded versatility for all the issues you mentioned. The AF may be due to your camera.  If you shoot landscape why use a superzoom?
 gavin's gear list:gavin's gear list
Sony RX100 III Canon EOS 5D Mark II Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF-S 17-85mm f/4-5.6 IS USM +5 more
diness Veteran Member • Posts: 3,758
Re: Unfair Review - Criticizing "Super-Zoom" for lack of IQ. Nature of Beast
-Serious vignetting
If you can't criticize it's iq in a review just because it's a super zoom, what can you do?  Of course being a super zoom introduce some flaws, but shouldn't a review still point them out?
 diness's gear list:diness's gear list
Canon EOS R Canon EF 135mm F2L USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM
-Serious vignetting
I looked again and I find the written review to be fine, but should probably be a 2.5 or 3 star review.  I hate 1 star reviews.  It basically should mean the lens doesn't work imo
Jon_T
Re: Disappointed
Vignetting:
AF Problems:
Would tend disagree with your analogy. In reality more like backward engineering in away; i.e., Canon (and others) marketing have a good idea on how much novice/ enthusiast photogs would be willing to pay for such a lens, then designs the lens that can be mfg/ sold for a novice/ enthusiast photogs price level.
Looking at the lenses in your gear, assume you would know why the EF 70-300mm f/4-5.6 L IS USM costs a lot more than the EF 75-300mm f/4-5.6 III, ditto for the EF 28-300mm f/3.5-5.6L IS USM than the EF-S 18-200mm IS.
Jon
clager Contributing Member • Posts: 824
Re: Disappointed
First lesson!  never buy a zoom with too much range. 18-200 is a heck of a range, too much range to be any good.
 clager's gear list:clager's gear list
Leica S2 Canon EOS-1D X Canon EOS 5D Mark III +1 more
Re: Disappointed
Well, "any good" is harsh.  It depends on the expectation of the photographer and what s/he wants to do with it.
Reviews should and usually do say this 18-200mm lens is good for this kind of user and users who are looking to blow images up to a x by y size should look elsewhere.
I spent a few years in the market research industry and I was constantly reminded that what I consider "good" may be redefined by others and no matter how logical I thought my evaluative criteria were, I was mostly in the minority.
For this lens, some will buy so that
  • they don't have change lenses; others so
  • it meets their budget; others so
  • they don't have to buy a bigger camera bag to house multiple lenses; others so
  • they can play with night shooting while still being able to do their family snaps...
Or any combination of the above.
For me some vignetting makes me feel like the photos have a retro-like feel, i.e. it added character; I only print less than 2% of my photos and then 99% are 6x4s.  99.9% of the time, my images will be seen on a computer screen via Flickr or Windows Photos.
Put together, "good" means little unless it is accompanied with some context based on purpose and personal taste.
Dave
Re: Disappointed
Canon seems to have done a creditable job with its 28-300, albeit at considerable cost and heft.  No free lunch.
Review - an assessment or examination of an item. So no I don't consider my review unfair as its a review of a lens that i owned. Also I gave 1 star not for IQ but because of AF issue (Nature of a review)
As said at the time I was just starting off and I had gotten that super zoom for versatility.
Yes I agree primes are the best when it comes to IQ but not all (serious photographers) consider primes ideal for their area of photography. There are times when you just can't zoom with your feet and you need the lens to do so instead.
Re: Disappointed
I figured as much this may could of been the cause. I was never able to separate the last inner glass elements.
I have since gotten rid of the lens and went with a canon 17-55 f/2.8 USM and never looked back. Problem solved
