Hombre de Maiz
Forum Enthusiast
- Messages
- 273
- Reaction score
- 60
yes, especially with the SL1 body this is for many an interesting alternative to mirrorless cameras (with better value for money, if you don't need the smallest kit).It completes well the IS STM set, you should get sharp, quality coverage from 10mm to 250mm, all in less than one kilogram weight.
I think that's a very minor loss in practice. If you really need DoF control in an ultrawide then the only way you will really get it is with a 16-35/2.8L on full frame. And four-stop IS is a much better solution for low light.... losing 2/3 stop on an already relatively dim lens and a smaller zoom range is less promising,
Agree, but I didn't have DOF control in mind; the viewfinder image does not improve by losing 2/3 stop ...I think that's a very minor loss in practice. If you really need DoF control in an ultrawide then the only way you will really get it is with a 16-35/2.8L on full frame. And four-stop IS is a much better solution for low light.... losing 2/3 stop on an already relatively dim lens and a smaller zoom range is less promising,
If it is close to the EFM 11-22 in optical quality, as the MTF curves suggest, it could be a very interesting lens. In that case I might decide to buy one and stay with APS-C body for a bit longer, because none of the current Canon FF bodies is really attractive for me. On the other side, if the 4/16-35 turns out to be much improved compared to the 17-40 that would make a future Canon FF body more attractive again. I'm hoping for a 6D like camera with tilt screen and better sensor (more DR and if possible a bit more resolution).You could contrive situations where it makes a difference (ultrawide skateboarding action shots under street lighting?) but they will be few and far between.
I'm not by nature an early adopter, but I'm totally sold on this lens.
A small point, but valid. Low light + f/5.6 + crop viewfinder is not a great combination.Agree, but I didn't have DOF control in mind; the viewfinder image does not improve by losing 2/3 stop ...I think that's a very minor loss in practice. If you really need DoF control in an ultrawide then the only way you will really get it is with a 16-35/2.8L on full frame. And four-stop IS is a much better solution for low light.... losing 2/3 stop on an already relatively dim lens and a smaller zoom range is less promising,
oh you'll love this lens for sure.I'll probably give it a go. Single mom budget here, and I've never owned anything wide angle before. Decent enough price for me to try it out and see how I like shooting at that end of the spectrum. Would I prefer the other one? Heck ya, but the reality of it doesn't fit my current financial life.
Tracey
Of course it is, one is EFM mount, the other is EFS... why compare the two? Pointless...Canon has announced an EF-S 10-18 F4.5-5.6 IS STM lens...
...regrettrably it is slower, heavier, larger and has a smaller focal range than the existing EF-M 11-22 F4-5.6 IS STM. Close but no cigar. What a shame.
Bottom line: Optically the EF-M 11-22 remains ahead of the two EF-S lenses judging by the MTF graphs.
The 11-22 makes a very compact and relatively high quality SWA solution. The system has its disadvantages, but the SL1/10-18 combo is a lot bigger. Depending on the subject the focus system might be a limitation (EOS M relatively slow) or an advantage (more accurate than PDAF especially with such a slow lens, and faster than contrast detect AF on the SL1).I had been planning on buying the 11-22 but now I think I will wait to see reviews of this lens before deciding. The focus limitations of the M are a bigger factor for me than a slight or imperceptible difference in IQ. I can't wait to see a real life comparison.
Same here, I might stick to APS-C for a bit longer and wait for an FF body that is more my taste. You can always sell the 10-18 later on, the cost for using it a year or so should be relatively low.This is confusing my master plan. I was going to stop buying EF-S lenses and start preparing/saving for full frame. I was going to get the then rumored 16-35/4 and sell the Sigma 17-50 and add either a 6D or 5D3. But for only $300, I could get into UWA for much much less.
I don't doubt that, but I do very very little low light photography. So I'm interested in the comparison in good light conditions.How much better? At least two, if not three stops worth of improved ISO noise performance.
As an owner of a 6D I am sure you are aware of the focus limitations of the M and the ability of the M to take pictures in focus does not alter things. If you tone down the fanaticism your input will be of more value.Focus limitations? What focus limitations? Do you see any focus limitations in any of these?
I am speculating while I wait for evidence. The MTF charts are promising and a small difference in MTF may not translate into much difference in actual use. The 17-40 which looks terrible on the chart consistently turns out stunning images in many users hands.That one will not be able to see the difference in IQ is your own partisan speculation.
