How serious is the AF problem in D7000?
Started Dec 9, 2013 | Discussions
nikonmaniak New Member • Posts: 14
Hi!
A few members are talking about auto-focusing problem in D7000 in different forums. Is it a universal problem or confined to few early batches? Is the problem too serious? I am asking this because I am planning to get a new D7000 at a bargain price in a day or two. Should I drop the plan and go for D7100 at a much higher price (60% more)? But my requirement doesn't justify this extra expenditure. Please advise.
Thanks.
Nikonmaniak
Nikon D7000 Nikon D7100
fotolopithecus Senior Member • Posts: 1,699
Re: How serious is the AF problem in D7000?
nikonmaniak wrote:
Hi!
Thanks.
Nikonmaniak
I had a D7000 until recently which I bought soon after it was released, and never had any auto-focus issues. I think most people don't, but some are ocd about auto-focus, and wee their pants if it's not perfect at all times. One pearl of wisdom I remember from one these guys was "the purpose of a dslr is to auto-focus."
 fotolopithecus's gear list:fotolopithecus's gear list
Nikon D610 Tamron SP AF 90mm F/2.8 Di Macro Nikon AF-S Nikkor 50mm f/1.8G
sapple
sapple Regular Member • Posts: 461
The AF in the 7000 is supposed to be the same as the d5200. I own a 5200 and rarely have much trouble. Biggest problem are birds in bushes. The camera will focus on a twig between me and the bird instead of the bird. The 7100 has more focus points so it is supposed to be better. Most people who make the upgrade do it for more than the af issues.
<a href="http://www.applenegative.com" target="_blank" title="www.applenegative.com" data-mce-href="http://www.applenegative.com">www.applenegative.com</a>
 sapple's gear list:sapple's gear list
Sony a7 II Sony FE 55mm F1.8 Sony FE 16-35mm F2.8 +3 more
David Lal Forum Pro • Posts: 10,293
Save up for the D7100
nikonmaniak wrote:
Hi!
In this forum D7K AF issues are usually ascribed to user error [sic]. Rightly or wrongly. However, if you read this recent post by Leonard Shepherd:
http://www.dpreview.com/forums/post/52678717
you will see that underlying all the user errors is perhaps a design 'feature'. Jim Holtz describes how to set up the camera to deal with all this:
http://www.dpreview.com/forums/post/52677495
Personally I'd save up the extra money needed for a D7100. Some say the AF in the D7100 is better even than the already superlative D300. If that is too much money then you might want to think about a secondhand D300/s although that would not be a particularly brilliant solution if you want the high ISO performance of the newer sensors.
David
scokill
scokill Veteran Member • Posts: 5,167
Birds in bushes?? AF is not a laser beam.
 scokill's gear list:scokill's gear list
Nikon D4 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S 70-200mm F2.8E FL ED VR
arrr
arrr Senior Member • Posts: 1,910
nikonmaniak wrote:
Hi!
Thanks.
Nikonmaniak
I have a couple of D7000s. Honestly I've never notice a universal AF issue with either of them. I do however have 2 lenses that back focus on those bodies. A 50mm f1.8 AF-D and 18-70 f4.5 AF-S. Both lenses work perfectly (most of the time) after af Micro Adjustment.
Also, I'd like to add that the D7100 is not a perfect system. It has a smaller buffer than the D300 and D7000. I've seen samples of high iso banding and hot pixels. Also HD video output is "soft" according to DPR.
 arrr's gear list:arrr's gear list
Nikon D610 Panasonic Lumix DMC-G7 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF Nikkor 50mm f/1.8D +7 more
Jeff4500
Jeff4500 Senior Member • Posts: 1,693
I have and use both the 7100 & the 7000. If $300 difference is not big deal get the 7100. If budget is a real concern get the 7000.
BTW the folks over at DVUSER certainly don't think the video is "soft". Nor do I, comparing apples and to apples (24P at 16 mpx on both cameras). When DPR said that the 1.3 crop video was soft I don't think they changed from the normal sharpening which need to be +1 or 2 as the jpg settings are used on the video.
 Jeff4500's gear list:Jeff4500's gear list
Panasonic 12-35mm F2.8 Panasonic Lumix DMC-GX8 Panasonic Lumix DMC-GX85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 14mm F2.5 ASPH +5 more
Danel Senior Member • Posts: 2,905
What auto focus problem?
nikonmaniak wrote:
Hi!
Thanks.
Nikonmaniak
I bought the D7000 the minute it was available to buy and I have never had any sort of auto focus problems what so ever.  I find the auto focus to be fast and accurate.  Of course all I have used it for is to take photos of subjects that I find interesting.  I haven't used it to take photos of, for example, lines of cereal boxes with an f/1.8 lens shot wide open using 39 point auto focus in dimly lit rooms.  I also have the camera set to focus priority not release priority, and I haven't shot many photos of people riding by on bikes through the rolled up windows of a moving car.  In short, I'm not a measurebater.  If your intent is to take photos of subjects that you find interesting you should be fine.  If you're intent is to use the camera to be an amateur tester and amateur camera reviewer, then I urge caution, because you may very well "discover" focus issues.  I do believe it is possible to find a way to take blurry photos with the D7000 if you "test it" long enough.
 Danel's gear list:Danel's gear list
Canon PowerShot SD800 IS Canon PowerShot G15 Nikon D7000 Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G ED VR II +5 more
morel22 Regular Member • Posts: 187
D7k doesn't suffer any universal AF problems! End of topic. Sorry to be a bit harsh here, but simple logic dictates that this is not true!
The D7k has been the hottest camera in the market for the past three years. The most recommended. The most sold in its category. And succeeding a best seller as well, the D90.
If it had such a maior universal problem, or even some complete batches with AF problem, then the whole blogosphere would be talking it, don't you think?
The D7k's popularity was even one of the reasons I went for it. It means more support, more reliability (in terms of feedback/update ratio), and simply more cred. And good cred means that these voices you are referring to on some forums, are either ignorant beginner voices, or trolling hateful ones (sometimes paid; happens on major forums! And on constant rate as well. Someone makes up a story, most of the time brings no data or evidence, and asks a question or makes a rant. Serves well for the search engines when someone is researching a popular product and comes across different threads with such topics.)
Could be that Nikon do it as well. Not claiming here that only Nikon are picked on. This became a regular activity over the internet. And obviously popular products are the most targeted.
And doesn't mean that you can't pick a D7k with no hardware defect! But seriously, no pattern of or any specific AF defect was reported or detected on mass!
sshoihet Senior Member • Posts: 2,603
nikonmaniak wrote:
Hi!
I wouldn't say that there was a widespread problem, the most significant issue is that the actual focus sensors are larger than the points in the viewfinder would suggest and this can make focusing on some subjects challenging, especially if they're small.
I have both the D7000 and D7100 and I suggest you get the D7100; there are many reasons in addition to the focus module for that but you'll have to decide for yourself.
You might also look at:
- Skin tones
- bracketing
- controls
- Auto ISO
- High ISO noise
I will shoot both together but there is never a time where I will choose to take the D7000 over the D7100 unless maybe I waned to do some insane shadow push... and in most cases, there is a better way to accomplish what I need to do.
 sshoihet's gear list:sshoihet's gear list
Nikon D7000 Canon EOS M Nikon D600 Nikon D7100 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR +14 more
Section10
Section10 Senior Member • Posts: 1,537
First I heard of an AF problem....which means there wasn't, probably means there's only individual camera trouble on some units and of course this forum is also the 'filter of troubleshooting' issues to some...
If I had choice between both, which I did, I chose the D7000 certainly not because it was better but because I got it for a much better deal, have a FF 24mp camera, and won't lose nearly as much money when I sell the D7000 for a newer nikon body when that gets released, (I wasn't entirely sold on the D7100)
Eventually there'll be built in wifi, improved ISO noise reduction to match the Sony's, I don't believe my Nikon is near that.
If you want a camera now to last years and have no need for upgrading any time, then D7100 is the better choice.
 Section10's gear list:Section10's gear list
Sony FE 55mm F1.8 Nikon D4 Sony a9 Zeiss Otus 1.4/55 Zeiss Batis 25mm F2 +3 more
kithg
kithg Veteran Member • Posts: 6,221
I am still climbing up the learning curve of my D7000. I believe that it has no focus problem. It does have a very sophisticated AF system among other camera controls that it takes a while to master. You have to have a good grip on what your lens can do and what your camera settings are. It could be that your lens isn't as sharp at its long end as you'd like. It could be that you have the camera set to shoot when you press the button, rather than when you achieve focus. Or you have the max ISO set inappropriately for your shooting habits. Or you're set to dynamic focus when you need single or vice versa. I've had all of these issues affect the sharpness of my pictures. The camera does beautifully if I tell it what to do, appropriately to the task at hand. And the D7100 is not less sophisticated. I believe you'll be happy with either one, once you master it.
 kithg's gear list:kithg's gear list
Nikon D7200 Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR Sigma 17-70mm F2.8-4 DC Macro OS HSM Nikkor AF-S 300mm f/4E PF ED VR +1 more
WTarcher77 Regular Member • Posts: 314
I was just chuckling about this the other day.......  After 30,000 shots or so, I am convinced that it works pretty well
NEVER use AFA...   Learn when to use AFS....  And in my case,leave in AFC 90% of the time.
bflood Senior Member • Posts: 1,738
My first thought is to tell you to buy for the future, not the present or past, and therefore you should get the 7100. But realistically, unless you've won the lottery lately, the price really does matter.
I got my D7000 a couple of years ago, and the only focus problem I've encountered happens when the camera's operator malfunctions (that's me). View NX2 shows the focus spot when it displays the image, and I found myself horrified by how often I was off-target when shooting at 400 mm. My focus problem was self-inflicted. It taught me to get better at aiming and keeping the focus spot on the target, and I'm much happier with my results these days. And as an odd coincidence, my lenses got sharper, too. Can you imagine that!
 bflood's gear list:bflood's gear list
Nikon D7000 Nikon D610 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S Nikkor 300mm f/4D ED-IF Nikon AF Nikkor 80-400mm f/4.5-5.6D ED VR +3 more
brucet
brucet Veteran Member • Posts: 3,039
The D7000 is not a point and shoot. Simple as that. So to get the best out of it the user needs to learn how to use it. It does have a learning curve. Some folks simply expect too much from an advance camera. Those same folk expect to have everything in a camera yet expect it to perform like a simple point n shoot. The D7000 gives you so many options that it's easy to get it wrong. Master it and you have a real keeper.
regards
 brucet's gear list:brucet's gear list
Nikon D7100 Nikon AF-S DX Nikkor 18-105mm F3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm F1.8G Tokina AT-X Pro 12-24mm f/4 DX II Nikon AF-S Nikkor 50mm f/1.8G
sleelio Junior Member • Posts: 28
After my experience with my D7000, I'm convinced that AF problems can happen with any camera and camera/lens combination - even the latest and greatest.  The fact that there are so many D7000s out there might make it seem that this camera has more problems than other models, but I bet the percentage of true "problem" cameras are similar from model to model.
I reached this conclusion after struggling to get sharp focus with my D7000.  I mostly shoot action/sports photos.  After reading many posts in this and other forums and acknowledging the difficulty in focusing on moving targets, I was very hesitant to blame the camera.  This led me to researching every button, dial and menu option on the D7000 - when to use what settings, how the autofocus works etc etc.  A few thousands photos later (with many well lit, non-moving, contrasty subjects), I finally took the camera back to where I bought it.  Since it was still under warranty, the shop strongly recommended sending the camera back to Nikon for calibration, rather than trying to make adjustments with the AF Fine tuning.  I also sent my 2 favorite lenses (35mm f/1.8 and 70-200mm f/2.8) in for calibration.
The camera just came back with a report stating they had adjusted the autofocus operation and adjusted the mirror angle.  The shop told me the camera should now be "right on - plus or minus, because there's no such thing as zero error tolerance."  I asked how the camera could have passed quality control when it was manufactured, and the shop said that the testing (and presumably tolerances) done at manufacturing was not as extensive or precise as when calibrating.  Same for the lenses.
I'm still waiting for the lenses to come back, so they must be doing something with them.  The shop said after they come back I may still need to fine tune the lenses, again because "there's no such thing as zero error", but that the amount of tuning should be small, if any.
Good luck - just be aware that any camera you get, regardless of model, could be absolutely perfect out of the box, or not.
 sleelio's gear list:sleelio's gear list
Nikon D50 Nikon D7000 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S DX Nikkor 35mm F1.8G
chuhsi Contributing Member • Posts: 999
my d7000 is with nikon right now for a 3rd pass at fixing the backfocus issue with all my lenses.
that said, i am probably one of the unlucky few to have gotten a bum camera.
it's a fantastic camera, especially because you can buy one so cheaply now. i have a brand new d7000 from black friday that i may keep as a backup.
 chuhsi's gear list:chuhsi's gear list
Nikon Df Nikon D4S Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 50mm f/1.4G Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +4 more
jonikon Veteran Member • Posts: 7,028
Individual D7000's may have focus issues, but I have no reason to believe there is anything wrong with the design of the D7000 AF system.  I have owned a D7000 since November of 2010 and have taken tens of thousands of photos with it, (including being the only photographer for three weddings),  and have had no complaints  with the AF system in my D7000 as it works very well.
BTW, I use Tokina, Nikon, Tamron and Sigma lenses and all AF well, with some requiring a very small amount of AF micro adjustment for maximum accuracy.
- Jon
 jonikon's gear list:jonikon's gear list
Nikon Coolpix A Nikon 1 V1 Nikon 1 V2 Fujifilm X-T10 Fujifilm X-T2 +11 more
GerardHaines Regular Member • Posts: 497
Show me an AF system that doesn't have trouble shooting birds/wildlife in bushes...that's what the manual focus switch is for. More focus points isn't going to help out the situation...in fact, it's just going to exacerbate it.  Personally, I'd start with a single point and go to manual if that doesn't work.
 GerardHaines's gear list:GerardHaines's gear list
Nikon D7000 Nikon D5100 Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR Nikon AF-S DX Nikkor 55-300mm f/4.5-5.6G ED VR Tokina AT-X Pro 11-16mm f/2.8 DX II +1 more
toomanycanons Forum Pro • Posts: 12,322
nikonmaniak wrote:
Hi!
Thanks.
Nikonmaniak
You can't be serious.
