Unxplained
New member
- Messages
- 3
- Reaction score
- 0
Hi,
I’ve run into a problem with my 60D that I can’t fix or make sense off. Hopefully it’s something really simple.
Everything went wrong after I used DSLR Remote Pro in Av mode to take some pictures at different exposures for HDR. The software worked fine and support says that you can’t reprogram the 60D using the USB connection so their software can’t be responsible.
Basically the problem is modes are not matching what is displayed on the mode dial and so the creative modes are no longer available. If I move the mode button so that the camcorder symbol next to the white arrow, to place the camera in movie mode, and the press INFO. button to bring up which mode the camera thinks it’s in. So for movie mode I see the settings / information (AFQuick, AWB, 1920, 25 etc) on the screen. If I cycle through the modes on the dial they don’t match the mode the camera thinks it’s in and some modes like Tv and Av can't be accessed.
On Dial - On Screen = Mode camera thinks it’s in
Movie - Movie
Night Portrait - Night Portrait
Sports - Sports
Close-up – Close-up
Landscape - Landscape
Portrait - Portrait
CA - Portrait (This is where things start to go wrong - ie. info screen does no change)
No flash in rectangle - Landscape (Displays mode as Landscape)
Green rectangle - Close-up
P - Sports
Tv - Night Portrait (should say Tv in top left of INFO. screen)
Av - Movie (should say Av in INFO screen but displays movie settings + viewfinder closed like movie mode)
M - Movie
B - P
C – P (dial now at other extreme and won’t rotate any further)
When the dial is set to M I’m able to “Clear all camera settings”. I’ve also cleared all “Camera user settings”. I upgraded the firmware from 1.1.0 to 1.1.1 to see if that would help but nothing seems to reset the camera back to how it was. Is it stuck in some sort of movie mode?
It doesn’t seem like a hardware fault, the dial is not slipping between settings and it won’t go past the end points. It seems more of a software settings issue but I can’t figure out what and there is always the possibility that something got changed while the USB cable was connected.
Does anyone have any idea what has happened or any suggestions on how to fix it? Is it possible to do a full hardware reset on the 60D? Please let me know if there are any other tests I can run to try and diagnose the problem.
Thanks,
Ian
Movie - Movie
Sports - Sports
Close-up – Close-up
Portrait - Portrait
P - Sports
M - Movie
B - P
Thanks,
Ian
