hjulenissen wrote:
TrapperJohn wrote:
A dye sub printer is also called a continuous tone printer, in that each pixel in the 300x300 is a unique color, produced by layering translucent spots of CMYK on top of each other.
Inkjets, which are halftone rather than continuous tone, do the same by mixing dots of CMYK next to each other to simulate the desired color.
So while a 1200x1200 inkjet might seem to be higher 'resolution' than a 300x300 dye sub contone printer, the inkjet uses a 16x16 matrix of adjacent dots to do what the dye sub printer does with one dot. In that respect, the inkjet has a lower pel (printable element, the smallest unit of a unique color) density than the dye sub, even though it appears to be much higher by raw specs.
OTOH, the inkjet doesn't cost nearly as much to operate.
I do miss my Oly P400 dye sub printer - it turned out lush prints that had an almost '3D' look to them. Plus, they were waterproof and did not fade. That printer finally died, after cranking out many great prints, even if the media did get a bit expensive.
I am not an expert on half-toning, but I believe that the dithering-method could be very intricate, meaning that a simple analysis ala "16x16 bins" can be misleading.
Even though some area is needed to generate some colour tone, this area might not be rectangular, and knowledge about the (high-res) input image could be used to draw sharp edges more "vector-like", or gradients with little stairstepping. Throw in knowledge that our vision is more sensitive to luminance detail than chrominance detail.
-h
"matrix", be it 16x16 or any other given form is easy to understand when explaining colour creation using primary ones (CMYK in this case). And yes, it is far more complex than "simple" dots inside square - this is where we draw the line between good and poor RIPs. The essence of halftoning/dithering is "more primary colour pixels, the better". The "problem" (rather call it beauty) of human vision is as you say "more sensitive to luminance detail than chrominance": well, true yet if target colour cannot be rendered in continuous tone fashion, the "resulting" pixels will appear dispersed to the point where our vision see it as chroma variation.
For example, lets look at the light blue sky colour: 70% white, 26% cyan, 3% magenta and 1% black (this is random composition). For the practical purposes, lets take primary rendering "matrix" to be 10x10 pixels to "compose" this colour. Years ago, the early inkjets woudl be 360 dpi, 4 colours, single droplet (dot) size. Technically speaking, if we imagine that the black dot is dead in the middle, it would appear 36 times per one inch - our eyes, being able to "see" luminance" better than chroma, would easily spot these black dots. For this reason technology has to come with either smaller droplet (dot) size combined and denser "matrix". Due to limitation how small the droplet can be (to be guaranteed to actually be printed), the solution was to go with shades of primary colour - all until or eye can no longer detect variation in luminance level.
Dye sub (continuous tone) printers actually work the other way around, chasing colours at acceptable "luminance" resolution. 300 dpi is very safe naked-eye resolution for (almost) all of humanity, most would "fail "resolution test around 220-250 dpi). But assuming we can resolve (at one time) some 12M colours (let's not debate this in further details), the "colour error" detection , though possible is irrelevant as it all boils down to luminance levels.
With digital photography, we talk about hi MP resolution - but either printing technology is pixel hungry. With dye-sub, 20MP camera will give 12x18 inch print at its native resolution (give/take) and will handle well that size with some 14-16MP (that one could not see the difference). But - the same rule applies for inkjet FOR VERY CLOSE INSPECTION by naked eye. The new (current) hi-end inkjets are perfect tools - the bottom line is that back in 1996 those who could see further in the future determined death of dye-subs in favor to cheaper inkjet technology, choice of media one can print onto and other advantages inkjet may have compared to dye subs, like power consumption. I mentioned the price of the unit back then - I should say that the Tabloid Extra print had fixed price of around $7, regardless if you printed image 1 inch in size or across the page (ribbon and media), Letter was around $3.50. I vividly remember some saying back then "the inkjet full bleed tabloid photo will cost less than a $1". Hmmm, were they actually right about it, I can't say as I don't use inkjets. I have ribbons and media for my old dye-subs that will last me a long, long time...
sorry, long post
