Are Sigma Foevon sensors better than regular bayer sensors of infrared or ultraviolet photography?
After all here every pixel collects all incoming light, so by my logic - there should be some advantage from that and removing filters from in front of the sensor should allow capturing broader spectrum of light with much higher quality then in regular bayer sensors.
With Bayer while shooting IR only red pixels respond, so your actual resolution is only 1/4th of the one camera have, so from 16 MPx color camera you have 4 MPx IR camera. Which is rather pathetic.
Same with UV - when using filter only blue pixels register UV light, so your actual resolution also falls down to 1/4th.
Does Sigma Foevon behave any better in that respect? Is it capable of capturing 4 times the true resolution of bayer filter in IR and UV spectrum?
Just imagine the implications for astrophotography. This would mean that basically your noise levels fall down by 75% when it comes for IR photography. This could be a real holy grail (next to modified Leica Monochrome).
