Leon Wittwer
I've printed about 30452 square inches of print, almost all of it at 2280 dpi. Something over half was on the Epson premium lustre paper. Almost all the rest was on Epson enhanced matte paper. It did not appear that the different papers used significantly different amount of inks. It is now clear that the set of cartridges that came with the printer did not have as much ink as the later purchased cartridges. This first set may have had only about half of the ink per cartridge as later cartridges. If I take the last 19807 square inches, the ink usage was 4.1 light magenta, 3.55 light cyan, 3.45 light black, 2.25 yellow, 1.65 magenta, 2 cyan, 1.77 matte black, and 1.05 photo black cartridges. This comes out to about 1000 square inches per cartridge. Assuming $10.76 per cartridge, the costs are $0.86 and $0.26 for a 8x10 and 4x6 inch print, respectively. If I take the last 10000 square inches printed, I get very close to the same numbers indicating that my ink use stabilized after the first cartridge set was used up. To get total costs you must add the paper costs. Other info on the 2200 can be found at the following URL.
http://www.dpreview.com/forums/read.asp?forum=1003&message=3399341
