PC UK said:
Erik Ohlson said:
In most cases the JPEG will do everything you need.
Very rarely the "RAW" will get a touch better, but in most cases only at the pixil-peeping level.
It's not really worth your trouble, IMHO.
-Erik
DP Review Supporter.
I agree
In good light, the camera's JPEG conversion software will be very goodand RAW processing saves you very little time, and if you do not want to do a lot of post processing, then JPEGs are a great way to save A LOT of time. ...
Agree.
In good and '
even' lighting, low ISO's and proper exposure will probably not see much difference between JPG and RAW.
However as the lighting conditions become lower and/or more adverse, and/ or as ISO increases the benefits of RAW's additional DR and better NR increases.
Member said:
The Lumix JPEG system also applies lens corrections - so that your wideangle zoom shot will have straight lines rather than bent ones in citiscape and architectural shots. ...
But at wide angle focal length an good RAW software's lens corrections can do a noticeably better job than Pany's in-camera's JPG corrections.
Below from my previous posts ...
Basically the majority of fixed-lens compacts with a 24mm equiv. to tele zoom lens, the lens image circle does not fully cover the sensor's edges/ corners at the WA. Hence the camera's JPG processing crops, corrects barrel distortion, and stretches the image to fill-in corners.
If you shoot 24mm equiv. as JPG+RAW you can view the unedited RAW image with an app like FastStone Image View to see actual image captured vs the corrected JPG image; e.g., JPG+RAW image downloaded from
PhotographyBlog.com TZ70 Review:
PhotographyBlog JPG. Compare this JPG with RAW image below to see amount of cropping at edges to the JPG image.
RAW image viewed with FastStone Image Viewer and saved as JPG to post here.
RAW image from PhotographyBlog I PP w/ DxO Optics Pro
Imaging Resource FZ1000 Review Sample image (FZ1000FAR2WTW)
Image below shows how much the FZ1000's JPG is crops the and upscales the back to the native 5472 x 3648 20MP resolution.
IR FZ1000FAR2WTW.RW2 RAW image opened in FastStone Image View and save as JPG w/o any edits.
Below DxO PhotoLab provides a wider field of view not possible from OOC JPG, and
DxO ViewPoint perspective corrections.
IR FZ1000FAR2WTW.RW2 RAW image processed with DxO PhotoLab & ViewPoint perspective corrections
Due to the wider PP RAW images' FOV, not going to be able to PP the OOC JPG's to match the PP RAW images.
Couple other older posts showing advantages of RAW:
FZ1000 sample images showing the JPG cropping/ stretching of image at the edges/ corners
HERE.
Benefits of RAW has highlights/ shadows beyond JPG's dynamic range even with averaging metering of highlights/ shadows of a dam
HERE. In high dynamic lighting range (highlights/ shadows) can be beyond the capabilities of JPG PP. Those who 'fully' understand that JPG uses method of "
lossy compression" why with RAW image you have much more of the sensor's image data to work with.
Member said:
... Keep RAW for the low light pictures, for where you know that you want to do a lot of "photoshopping" later. ...
Not just "low light", in less than 'good lighting' (e.g., outdoor sports on an cloudy/ overcast day) will need higher ISO's for fast enough shutter speed to prevent subject blurring. At higher ISO's the Pany's in-camera NR increasingly decimates the fine details.
Do not know which RAW app you're using, but with latter versions of Photoshop Elements and DxO Optics Pro/ PhotoLab the 'opened' RAW image (without any edits) is as good, if not better, than the OOC JPG.
Member said:
... Always remember - that the camera has a very very clever trick that is often ignored - use the "scene" modes - and the JPEG compression algorithms will apply a very different pattern of sharpening, contrast, noise reduction, colour control to the image. This simple step can make a great deal of difference to your finished image. Landscapes are greener and sharper - things that would look bad on a portrait, which wants more exposure and lower contrast etc. ...
Agree the 'Scene' modes are great for those who do not to do any PP.
As always to each his/ her own preferences/ needs.
I can get better overall results from RAW PP than scene modes, and for 'myself' does not take me any longer to PP RAW or doing the same amount of PP to a JPG.
With DxO PhotoLab with a batch of images under similar lighting conditions, all I have to do PP the first image, copy the RAW corrections, and then post to all the other images.
I started PP RAW images out of necessity as the early DSLR's (2005) in-camera JPG did correct for lens distortions or CA.
Being one who had a dark room for 10+ years processing film negatives and prints, RAW processing images far easier and dryer, and provides similar amount of control over the image processing.
Hence as to:
For LOT of the shooting I do, "I" can see difference in less than the "
pixil-peeping level" of images and in prints.
Member said:
Again no 'trouble' for myself as PP RAW does not take me any longer than doing the same amount of PP to OOC JPG, and is definitely worth shooting/ PP RAW images for times you do not have good/ even lighting conditions; e.g.,
Prior to buying FZ80 below are a couple JPG+RAW sample images I downloaded from the PhotoLab FZ82 Review to see how well the RAW image could be PP (images downsized to 5MP—no '
pixil-peeping level' needed to see differences).
OOC JPG
PP RAW image; note image wider FOV
OOC JPG
PP RAW image
The 'bottom line', it's NOT an "JPG vs. RAW" as some try to make it with comments that are mostly subjective than objective; RAW provides an 'option' to work with much more of the sensor's image data to get better highlights/ shadows recovery, NR and lens corrections.
Jon
