countrybutterfly
Leading Member
- Messages
- 661
- Reaction score
- 128
Some people say the flash is bad for newborns. I am wondering if I shoot through umbrella and put it to side if it would still be too much of bouncing off wall? or should I get a light?
+1there are no issues with bounced/diffused flash and newborns. As long as you're not subjecting them to an hour long shoot with 500 flashed shots or blasting them strait on with flash from 2 feet away, you'll be fine and so will they.
What if the ambient light sucks?to get more ambient light, and less flash.
--Some people say the flash is bad for newborns. I am wondering if I shoot through umbrella and put it to side if it would still be too much of bouncing off wall? or should I get a light?
Shooting through an umberella will reduce the intensity of the flash which would theoretically be easier on the eyes but in a earlier DPR posting on this subject good medical opinion was that flash would not harm newborn eyes. The umberella will soften the light (separate charactristic from intensity) which could vary well improve the photos.Well I was thinking if I shoot through the umbrella wont that soften the light alot and wouldn't be as harsh on the babys eyes?
You're mixing up a few things.Also heres something else to think about. If im doing newborn photo shoots. And not using flash. How do I accomplish this with a black background. Because black backgrounds the shutter needs to be high and room not so bright.
A tiny diffuser will not necessarily reduce intensity, either.The film canister cut intensity but did little or nothing toward changing the characteristics of the light because it did not increase the size of the light compared to the subject. It is also unlikely that it directed enough light at the ceilings and wall to significantly diffuse the light.
Repeat after me: "Large light source = soft light, small light source = hard light."
