I'd like to make it clear the message I'm posting isn't to wind anyone up.... but can you find me any photos where people have used speedlight beauty dish's to any decent effect?
I've only ever used bd or assisted when people have used BD, and we rely on the edge of the lighting to be ocnstantly moved (hence why we keep the modelling light on).
I would love to see examples of how a speedlight beauty dish can be used well, as I've always found it hard to believe that they are any better than a octabox or flagged reflector at such small sizes.
MY understanding (which maybe be incomplete) is that unless the Bd is large, the "magic" bit of light is too small to be of use, and if you use a BD w/ a sock, you may as well use an octa or softliter.
[any constructive repleis welcomed].
cheers
url : http://www.al-overdrive.com
rss : tiny.cc/pngnG
Twitter : http://twitter.com/AlOverdrive
--http://www.lumodi.com/buy.html
I use the lumodi. The owner will answer any questions you have by calling the number on the website. I am very rough on mine and although it is very light weight it has stood up well. The owner is about to launch an new larger version.
http://www.jmledy.com
http://www.youtube.com/watch?v=Wi40rP_k-XA
Hey,
Thakns for taking the time to post those images. To my eyes they look no different to anything I've shot using an octabox (without the diffuser) or a gridded reflector.
If you can rememebr - where was the Bd pointed at for th efirst shot (the model in the pruple dress)?
cheers
rss : tiny.cc/pngnG
No. Sorry. But there are adapters around to mount speedlights to just about any "mainline" studio flash accessories, whether it's a Bowens S mount, a Paul Buff mount, or a Profoto mount.Can anyone tell me what's the largest beauty dish available designed to fit a Speedlite that they know of?
That is not true. Beauty dishes are pretty high efficiency light sources. They take in over half a flash's "sphere of light" and reflect that pretty much straight forward with a lightly textured aluminum surface. So, as long as you're not operating at insane distances from the subject (like trying to use a beauty dish to light a subject 10 feet away) you're transferring a good portion of a flash's energy towards the subject. Losses are typically only a stop or two.I'm told the big ones need powerful studio strobes.
This whole "bigger modifiers need more power" thing is a misconception that comes from the "real" rule "bigger subjects need more power". Because bigger subjects usually demand bigger modifiers, people got it into their heads that it's the bigger modifiers that cause the need for more power. At optimal "subject distance = reflector size" portrait work, you need pretty much the same amount of power for a 2 foot softbox as a 6 foot one. I can (and have) run a 7 foot octo off a 300 w-s studio strobe.
Rahon Klavanian 1912-2008.
Armenian genocide survivor, amazing cook, scrabble master, and loving grandmother. You will be missed.
Ciao! Joseph
http://www.swissarmyfork.com
--Hi,
cheers
rss : tiny.cc/pngnG
--Speedlight or not, it's the light that the modifier produces that matters. The idea, as I understand it, of using a standard large beauty dish is to get soft light with a bit more definition and contrast than a similar sized softbox. If you put a sock on the front, you get softer light from the diffusion but still a lot of control. The main issue with using a beauty dish with a speed light is power.
All else equal, a smaller beauty dish will have harder light that a larger one. But if it's really close, a small dish with a speedlight might be really interesting.
It's all a matter of what kind of light one wants to create.
--Hi,
cheers
rss : tiny.cc/pngnG
-Dan Rode
http://rodephoto.com
Trevor
--That is not true. Beauty dishes are pretty high efficiency light sources. They take in over half a flash's "sphere of light" and reflect that pretty much straight forward with a lightly textured aluminum surface. So, as long as you're not operating at insane distances from the subject (like trying to use a beauty dish to light a subject 10 feet away) you're transferring a good portion of a flash's energy towards the subject. Losses are typically only a stop or two.I'm told the big ones need powerful studio strobes.
Ciao! Joseph
