Macro lens advice
TDon187
Member
UK
Hi all
Currently own a 500D with 18-55mm kit lens, 55-250mm and a 50mm f1.8 II
Really want to start taking macro shots, but can't break the bank. Are there any decent lenses out there at around £250. I've seen the 50mm macro but is it worth having that as well as the 1.8 II?
thanks in advance
Most economical entry into macro shooting is to get a close-up lens like the Canon 250D. It screws onto the front of the lens like a filter and allows much closer focusing and macro magnification. The Canon 250D and 500D are 2-element designs that are better corrected for CA than cheaper single element close-up lenses.
Hi all
thanks in advance
Unapologetic Canon Apologist ;)
A used Canon 60mm macro would fit the bill.The 50mm macro takes an additional piece (converter) to get to 1:1. So make sure it's included. I prefer the 60mm for a lot of reasons.
Just to be clear - when I say I own a 500D I'm referring to the camera body (I see there is also a 500D close up lens)
So I can get a 250D close up lens and screw that to the front of one of my current lenses?
Would that provide a better/comparable/worse image than if I bought a set of extension tubes?
used 100mm f/2.8 macro?
That lens has produced some of my best photographs - macro or not.
The 50 macro is 2.5 but then you add the converter . Get the 60 mm 2.8 - newer , better coatings , a little more working distance than the 50 -- or a 100 mm - more working distance than the 60 .
1st it's a hobby
7D gripped XTI gripped
Canon - efs 10-22 , 17-55 , ef 18-55 IS
EF 28-90 , 28 @ 2.8 , 50 @1.8 , 28-135 IS
L's 35-350 , 70-200 MK II IS
Quantaray lens 70-300 macro
Sigma 135 - 400
2X III , Life Size converter
KSM filters for all
kenko auto tubes , EF 25
You can get an extension tube and put it on your 50mm to take macro shots. Then you can see how much you like it.
Hi all
thanks in advance
a 60mm macro would be the best choice (unless you go for 100mm).
cheaper are extension tubes and close-up lenses,
here is some info about how they work:
http://photonius.wikispaces.com/Close-up+%26+Macro
Life is short, time to zoom in ©
I don't know if this will help you, but I happened to shoot this today with my T2i + 55-250 + 500D close-up. Just a quick shot, and I have no idea what it is, which is really why I shot it. This is a 100% crop:
This is the resized uncropped shot:
I'm not interested enough in macro to get a macro lens, and the 500D lets me gross out my friends just fine :)
There is also the option of the Sigma 50f2.8 for macro work. A longer focal length might be better for some macro applications, like insects. However, the Sigma is sharp and less expensive than the Canon 60.
If I had the cash and wanted a shorter macro lens, I'd get the Canon 60. I own the Canon 100 and the Sigma 50 - both are good lenses, but I paid much less for the Sigma. The Sigma 50 was 1/2 the price of the Canon 100.
Not what you want to hear, perhaps, but the EF-S 60mm is remarkably sharp. I absent-mindedly snapped a photo of my car's dashboard, and every grain of dust was very visible. I mostly use the lens at work, to photograph circuit boards from a copy stand. It's sharp enough to capture the smallest chip markings, as long as the lighting is correct. This was the reason for the purchase.
The EF-S 60mm is truly a great lens.
That said, the 17-55mm EF-S kit lens also focuses very closely, and I suggest that you work with it and exhaust it before buying a macro, because that way, you will know exactly what, if anything, your photos lack. I photographed cherry blossoms with the 17-55 last week, and the detail was fabulous.
I have a 100mm macro, the non L version. I really like that lens, and with the new L being out, I assume you can find a used non L for cheap.
Last week I bought the Kenko extension tube set, bringing my magnifaction to X2-ish (I believe). I am really happy with the ubes so far, below are a few images I shot over the past couple days.
Also, I more or less found using the tubes with my 50mm 1.4 and my 24-105 L worthless. It turned them both into macro lenses, however I felt the quality was not present that I was getting in the actual macro lens and the tubes.
Here is a link I just found that shows more or less what I was seeing with the 50 and tubes:
http://forums.dpreview.com/forums/read.asp?forum=1029&message=26032436
My setup includes a 5DII, the MT-24EX dual flash, 100mm macro and Kenko extension tubes.
Here are a few images with the tubes and 100mm (shot at f32 if I remember correctly):
BTW, the bug inside the flower pic was an accident. That flower was so small I had no idea that bug was inside.
No doubt EF-S 60mm. I have that one and I love it.
If you want to break the bank 17-55mm. The 100mm f/2.8 is a third great lens and also great (and the only one) if you decide to go full frame in the future.
Bo Persson, M.A.
Independent Fashion Consultant & Researcher
[email protected]
http://bopersson64.wordpress.com/
Skype name bossep64
http://culturedevelopmentandresearch-cedar.freehomepage.com/
http://www.flickr.com/photos/76021273@N00/
http://www.cig.canon-europe.com/a?i=0sgcbH0TLC
You can do it because you believe you can do it. So do it!
I bought the 100f2.8 USM macro in December. I thought it would be a handy tool if I ever decided to do some macro. I took it with me the other day and snapped off a few shots. No hood, no filter, no nothing just a few quick shots to try it out. I've attached some of the crops. I like it a lot and am looking forward to the next orchid season. Granted I'm only an amateur and have a lot to learn but that's what I love about photography, you're always learning.
