SD Card Formatting
DonDeJ
Member
AL, US
I started to see the write time to my A-Data 32 GB SD card increase on my HS-10. After checking New Egg's web site, I ran across the following link to the SD Association's web site for a free SD formating utility. I tried the utility and it produced noticeably faster write times. As the disclaimer goes, your results may vary. Be sure to download the manual.
http://www.sdcard.org/consumers/formatter_3/
Don
Is A-data 32gb running ok with hs10?
I have Transcend 32gb sdhc and after a few dozen shots it is loosing format and all the photos :-(
Could you give the exact model of your a-data card?
I had such a problem already and the official SD formatting utility solved it.
My A-Data SD card has no model number listed but is a 32 GB Class 10 card. Check the reviews at Newegg.com and the SD Association's manual. The formatting utility seems to be solving many issues. Much like low level formatting a hard disk drive.
Don
I always formatted my cards using the in camera formatting and Windows but they grew slower over time. The SD Association does not address in-camera formatting. Their statement reads "The SD Formatter formats SD/SDHC/SDXC Cards optimizing with these card’s performance etc.. It is strongly recommended to use the SD Formatter to format SD/SDHC/SDXC Cards rather than using formatting tools provided with operating systems. In general, formatting tools provided with operating systems can format various storage media including SD/SDHC/SDXC Cards, but it may not be optimized for SD/SDHC/SDXC Cards and it may result in lower performance than using the SD Formatter".
To answer one of the previous questions, yes the A-Data 16 and 32 GB Class 10 cards are working fine with the HS-10.
Don
The formatter prepares the card properly IAW association format structure. Then the camera sets up the file structure needed for that particular camera.
Currently shooting:
Canon Powershot G12
Canon Rebel Xs DSLR with kit lens,
50mm F1.8 II lens, and 55-250mm IS telephoto
Casio EX-FH100
Casio EX-Z400
Casio EX-Z2000
Fujifilm F70exr
Panasonic LX3
Sanyo HD2000 HD camcorder/8 and 12 megapixel stills
Sony DSC-TX7
Don
Thank you Don for information about SD formatter.
It helped, my 32gb sdhc now is running OK.
I performed full format with overwriting the whole data space by sd formatter (took more than 1 hour), and then, right after, one more format by hs10 (maybe not necessary).
Finally I filled the card totally with pictures and movies by hs10 with no signs of any arrors.
Thank you
after you have formatted the card with SD FOrmatter , why have you repeated the format with HS10?
Don
Thank you
S200EXR
Just in case, to make the FAT and directory structure exactly what the hs10 needs.
I am not sure if this was really necessary.
As I understand the problem, SD formatter in overwrite mode cleared the whole data space and the FAT space, but the FAT and/or directory structure could be not exactly in form expected by hs10.
I cannot justify it more, I am not an expert in this field. Anyway, 16 gb transcend sdhc has not needed any special treatment, unlike the 32 gb sdhc (transcend as well)
