Compare it's output with the EPL1, no comparison.Are you sure we're talking about the same camera? Dpreview giving it a gold award and all.![]()
So you point down at an object in the foreground because you want it in focus (and the large aperture makes focus more critical than usual for a compact). Then you recompose and get a lot of sky in your scene that wasn't there when you locked both focus and exposure.It looks like a very compelling camera.
On the cons:
I don't know why you can't half-press the shutter, then recompose. Surely this camera focus-locks if you hold the shutter half way down, the same as (all?) other cameras have done since the dawn of AF....
The Lumix models this is based on do all of that. Plus they start wider. Even back as far as the LX1 they do the focus lock and AEL.So you point down at an object in the foreground because you want it in focus (and the large aperture makes focus more critical than usual for a compact). Then you recompose and get a lot of sky in your scene that wasn't there when you locked both focus and exposure.It looks like a very compelling camera.
On the cons:
And voila! Your sky is completely overexposed.
Sure you can come up with workarounds such as switching the camera to MF mode (4 button presses) once you've focused. Or you can play a game of trial and error with exposure compensation (at which point you're essentially manually exposing without a meter).
But the easiest solution would be the ability to lock the focus and exposure independently (either by AEL on the scene, then focus lock with shutter button, recompose and shoot, or AFL on the subject, recompose and take exposure from the scene with shutter button and shoot). Just as almost all cameras allow you to do.
Richard - dpreview.com
--So you point down at an object in the foreground because you want it in focus (and the large aperture makes focus more critical than usual for a compact). Then you recompose and get a lot of sky in your scene that wasn't there when you locked both focus and exposure.It looks like a very compelling camera.
On the cons:
What lens' are you going to have on the EPL1?Compare it's output with the EPL1, no comparison.Are you sure we're talking about the same camera? Dpreview giving it a gold award and all.![]()
AGREEOlympus deserves a pat on the back. They saw where the other enthusiast cameras lack and produced worthy competitor. Hot shoe, EVF port, very fast versatile lens, wireless flash control... and yet still pocketable with a good control interface.
XZ-1 + EPL2 + E-5 would be my dream set.
Seth
Can you do as I do on the LX1, simply focus and then switch to MF (assuming it at least has a switch for that like the Lumix cameras do)? Then recompose and meter normally whilst the focus remains locked by the act of switching to MF mode.So you point down at an object in the foreground because you want it in focus (and the large aperture makes focus more critical than usual for a compact). Then you recompose and get a lot of sky in your scene that wasn't there when you locked both focus and exposure.It looks like a very compelling camera.
On the cons:
