Just to followup. I had fully expected the 1DIV to successfully AF in the simple panning test based on Canons literature. I am surprised. But more surprised that others on this forum are not also surprised. i would suggest you try this simple test outdoors on an isolated object, mailbox, birdfeeder, etc and see what results you get.
A bird in the viewfinder is worth...
OK I did more research since noone seems to be able to account for the AF problem(?). Herte is a quote from Canon:
When using C.Fn III-8 AF Expansion with option 3: ‘Use all 45 points’ selected, during AI Servo AF, (if the center AF point is manually selected), 6 AF points in the rows above and below, and 3 AF points to the right and left (total 18 focus points) are available. The AF Expansion area follows the subject wherever it moves within the 45-point AF coverage area. All 45 AF points operate in this instance.
So it seems what I was trying to do is only possible if the manually selected AF point is the center AF point. I will try the test again with center point and pan right and left acros the FOV.
