I was recently taking portraits with my D90 mounted on a flash bracket, with SB-900 connected to the camera via SC-29 cord and my 24-70 f2.8 on the front (pretty heavy gear). The whole setup was on a tripod, as I was using slow-sync with the flash for balanced lighting. Unfortunately, one of the legs on the tripod collapsed because of a cam-clamp breaking. The gear did not just tip over to the ground, but fell off a ledge into the bottom of a drained water fountain (see attached photo). The fall was about 9 feet, about the distance from the top of the water bridge to the bottom where the people are standing in the photo. The posted shot was taken 5 minutes before the fall. As you can imagine, I practically had to change my underwear after I watched this horrible sequence happen before my eyes, with no way to do anything about it. Remarkably, the only damage was a tweaked tripod mounting socket on the camera, with a crack on either side of the socket in the body plastic, some scratches on the SB-900, some fairly deep gouges on the flash bracket, and the lens has 3 dents on the end of the lens, 1 of which makes it difficult to screw in a filter due to the threads being pushed in a bit. To be honest, I expected to find the end lens element shattered since I had no protection on the end. I did not have a filter or the lens hood on at the time (stupid me - I usually have both on most of the time). Luckily, the glass is perfect.
As for the tripod, it is in the landfill where it belongs (still cussing it today!)
All the other equipment still functions fine, and even the lens is still taking pretty good photos, but...now the zoom ring has a bit of a grinding sound, especially between 24 and 35mm. Also, a soft spot (CA) in the extreme bottom right of images taken at 24mm that I did not notice before. I am wondering what other's opinions are about sending in the lens for a repair. I would like a new end installed(the one with the filter threads that also holds the end lens element) to replace the dented one, and the grinding fixed. Can Nikon fix other problems with the lens while they have it too? Like maybe checking alignment of the lenses and testing it to make sure it is calibrated as good as possible? If so, how much is this likely to cost? Any experience with similar issues or repairs to higher end lenses that others can report would be helpful. Thanks!
Click zoom out if this opens at 100% (it did on my screen).
K.B.
K.B.
