Sean Richard
New member
I was looking at a these to lenses. the f1.4 is listed as a wide angle lens but the f1.8 is listed as normal fixed lens. Beginner question but Seeing as there both 35mm what is the difference?
Also. the DX lens is brilliant for the price. The FX lens is just plain brilliant, but painfully priced.Another difference is that the 35 f/1.8 DX doesn't quite (almost, but not quite) cover the FX frame.
Well futureshop is not a camera store. They probably sell more fridges than they do cameras.Oddly, many resellers do mark the 35/1.8 as a "wide angle" lens. I know Futureshop does.
Henrys lists Sony's 35/1.8 as "wide-angle".Well futureshop is not a camera store. They probably sell more fridges than they do cameras.Oddly, many resellers do mark the 35/1.8 as a "wide angle" lens. I know Futureshop does.
See my plan (in my profile) for what I shoot with. See my gallery for images I find amusing.
The normal definition of wide is a lens having a focal length wider than the diagonal of the format it is intended to be used on.Anything below 50mm is wide,
The DX diagonal is 28 mm (according to Pythagora's theorem, which is exact).The normal definition of wide is a lens having a focal length wider than the diagonal of the format it is intended to be used on.
The format sizes for medium format are around 80mm (depending on which medium format), 45mm for FX and 35mm for DX.
No matter who many camera stores list it wrongly - it's still wrong. 35 (give or take a few mm) is the normal focal length on DX. Period.Henrys lists Sony's 35/1.8 as "wide-angle".
Adorama lists the same Sony 35/1.8 as "wide angle". They also list the Nikon 35/1.8DX as "wide angle".
KEH lists the Nikon 35/1.8 as "wide angle"
Checkmate.
I think the "normal" lenses for many formats are a wee bit longer than the sensor diagonal (even though the formal definition mentioned by you and LS above is of course correct).The DX diagonal is 28 mm (according to Pythagora's theorem, which is exact).
Therefore, 35 mm is not a "normal" lens on DX, but slightly on the tele side.
The same holds for 50 mm on FX/FF. The diagonal of a 24x36 mm rectangle is 43 mm (if Pythagora was right).
The normal lens on FX is the CV 40/2 Ultron or Nikkor 45/2.8. This is the reason why many photographers considered the 35 mm focal length as "normal" on 24x36 many years ago, and a better alternative to 50 mm.
I think that lens manufactures think the normal lens is a bit longer than the sensor diagonalI think the "normal" lenses for many formats are a wee bit longer than the sensor diagonal (even though the formal definition mentioned by you and LS above is of course correct).
