CA when present must be the first thing corrected for my sensibility. It makes quite the difference when developing and the final sharpening is applied. Vignetting - I often apply some; concerns depend on the amount any particular lens introduces, and the objective. Distortion - depends on the subject being presented. IMO, of course. I like to turn to PTlens to address all three issues.Although all three can be corrected in photoshop (ACR) or DPP, among these three lens problems, which one is hard to correct? Which one degrade photo quality more?
It really depends on the extent of the aberration. CA can take many forms, some of which are more difficult to deal with than others. Geometric distortions when they are in the form of simple barreling or pin cushioning can be easy to correct, but some lenses, especially some wide angle lens, have quite complex ‘wave’ or ‘sombrero’ distortions. When you have complex geometric distortion, then it is best to use a program that uses corrections specific to that lens. PTLens and DPP use a database of information for specific lenses at different apertures and focal lengths, Photoshop only has general purpose correction tools, unless you use third party plugins,Although all three can be corrected in photoshop (ACR) or DPP, among these three lens problems, which one is hard to correct?
Again it depends on the extent, and in many cases on the specific shot parameters. For example, minor light fall off at the edges is easy to correct, but if your shot was at a fairly high ISO value, then lightning the edges will cause a significant increase in noise levels, in the same way that using software to brighten an underexposed high ISO shot will increase noise.Which one degrade photo quality more?
you already got some comments.Although all three can be corrected in photoshop (ACR) or DPP, among these three lens problems, which one is hard to correct? Which one degrade photo quality more?
Now, if I want to buy a lens and want to trade-off among these lens faults, then how do I weight those to reach a decision?Although all three can be corrected in photoshop (ACR) or DPP, among these three lens problems, which one is hard to correct? Which one degrade photo quality more?
My path in that regard was simply to buy the best lens I could rationalize affording, and work with it until you become intimate with it's strengths and weaknesses. Basically, use that to get the experience to answer that very question [g].Now, if I want to buy a lens and want to trade-off among these lens faults, then how do I weight those to reach a decision?Although all three can be corrected in photoshop (ACR) or DPP, among these three lens problems, which one is hard to correct? Which one degrade photo quality more?
Since CA, Vignetting, & Distortion can be corrected by software, your priority should be the resolution, sharpness, contrast and build quality of the lens.Now, if I want to buy a lens and want to trade-off among these lens faults, then how do I weight those to reach a decision?
Well, after the explanations above, you should see yourselves actually.Now, if I want to buy a lens and want to trade-off among these lens faults, then how do I weight those to reach a decision?Although all three can be corrected in photoshop (ACR) or DPP, among these three lens problems, which one is hard to correct? Which one degrade photo quality more?
Vignetting is very easy to fix. Distortion (by which I assume you mean barrel/pincushion distortion) is usually pretty easy to fix in post, though with some lenses, notably zooms, it can be a bit trickier. CA is usually pretty easy to fix, too, though I suppose it might be "harder" since the correction values vary from lens to lens, FL to FL, and so on.Although all three can be corrected in photoshop (ACR) or DPP, among these three lens problems, which one is hard to correct? Which one degrade photo quality more?
You have to differentiate between lateral CA and longitudinal CA. Good luck correcting LoCA (of which purple fringing is a sub-type), it can in practice be almost impossible to remove. LaCA can offen be removed quite effective, but better start out with an image without CA, or at least low level CA.CA often doesn't improve much with stopping down, so it's always there at the edges. It deteriorates resolution, and in contrasty situations you get these horribly coloured edges. It can be fixed relatively easily, though not perfectly, even in jpg files in e.g. Photoshop, without much loss of resolution.
quite correct, though in the usual lens test sites, usually only lateral CA is measured, (so, that's the major measure you have to compare different lenses against each other for CA), and that's the one that can be corrected. So, yes, one shouldn't consider a lens that has lots of purple fringing, because that can't be corrected.You have to differentiate between lateral CA and longitudinal CA. Good luck correcting LoCA (of which purple fringing is a sub-type), it can in practice be almost impossible to remove. LaCA can offen be removed quite effective, but better start out with an image without CA, or at least low level CA.CA often doesn't improve much with stopping down, so it's always there at the edges. It deteriorates resolution, and in contrasty situations you get these horribly coloured edges. It can be fixed relatively easily, though not perfectly, even in jpg files in e.g. Photoshop, without much loss of resolution.
- Jan
