nickoly
I have heard stories about that but had forgotten. I don't think this problem extends to W7 but that needs to be checked. I was actually thinking you probably wouldn't actually have anything newer than XP! And, on reflection, I agree, re-using Vista is not a good idea. I don't actually have any trouble with it, I just find it so tedious to use.
At least your brother-in-law is realistic to enough to be aware that your needs are different, and you may find that building your own through him is a good way to save money.
On further reflection, you may even find that, on proper examination, your problems are software, not hardware. He may be able to help on that once you explain better what you mean by "about to self implode".
Hardware problems are usually sudden, fatal, and arrive without warning.
Software problems usually accumulate and are often fixable at no cost.
If your real problem is incompatibility between Vista and CS3, a new box is simply a vehicle for a new o/s, which may well be fine if it was installed on your old one.
In short, if nothing is actually broken, you may find that a copy of XP off eBay for $25 is all you really need.
I have Vista and that has been a big problem- according to the computer people I have talked to that vista and cs3 were both new and noone knew how they would work together.
