I'm really "green" on this subject. Is it true that the HDR feature on more of the newest camera models is designed to merge together several (2 or 3)images of the same subject at differing metering settings? The camera actually blends them together to make a "best" image which is actually a compilation of those images?
If I'm right so far.......... How quickly are these 2 or 3 similar images captured? Faster if the camera has a higher FPS rate? Does this require a tripod? OR, are the multiple images greated based on only one snap of the shutter; with the internal workings of the camera in complete control of the blending?
If this is all wrong, please explain(slowly and carefully). This sounds like just a feature that I could use; as I'm constantly struggling with metering issues.
And finally, can this be found on entry-level cameras? If so, which ones?
Thanks so much.
Thanks so much.
