steven mulder
Forum Enthusiast
it's still more cost effective to have a commercial printer "do" your prints for you than doing a 16X20 or 11x14 at home!
steven mulder
steven mulder
--it's still more cost effective to have a commercial printer "do"
steven mulder
----it's still more cost effective to have a commercial printer "do"
steven mulder
If you don't snap it, nobody will snap it for you ...
Kafrifelle (Yves P.) Owner of DSC-F707,
No BFS, No hassle but strong vignetting on left
VCL-MHG07A, HVL-F1000 and some close up lenses ...
http://www.pbase.com/kafrifelle
------it's still more cost effective to have a commercial printer "do"
steven mulder
steven mulder
steven mulder
Great post. I never really though of doing that way. Duh, cut the paper in half. I was going to buy a Sony dye sub for 4x6. This seems much more cost effective. I only really looked at how much 8x10 versus 4x6 printing that I would be doing.I buy very very high quality, premium photographic glossy papers
in bulk. The box of 500, 8.5 x 11 paper costs approximately $150
on the internet including shipping, and ofcourse no sales tax.
This turns out to be 30 cents per full page. I cut this paper in
half, each half is now 5.5 x 8.5. I use this half to print
pictures up to 5 x8. My HP 990 printer requires 0.5 inch margin on
all sides. After printing, sometimes I cut the borders to make the
prints borderless. I use a paper cutter for all of this.
--------it's still more cost effective to have a commercial printer "do"
steven mulder
steven mulder
This may be in another thread, but ... could you illuminate us?
Thanks, Ann
Thanks, Ann
pictures to raise money for the temple.
--1. Walmart is OK, you can print with their kodak picture maker. I
found
that color is really off, every photo has a yellowish tint to it.
This is not
good for portraits. Price is 49 cents for 4*6 and $4.74 for 8*10
prints.
2. Walgreens is SUPERB. They have installed a new facility called
Aladin
photo counter 2 weeks ago. You can take your picture their in a CD
(I do not know if they take memory stick directly) and they print
it on
their regular machine. This is a 1 hour service. Prints are
exceptionally
good. I have tried only 4*6 so far and the cost is 38 cents per
photo. I
used to shoot with 35 mm slr with portrait lens, and the prints that I
got from Walgreens using f707 is definitely better than prints from my
SLR. If you are familiar with 35 mm SLR and fuji NPS portrait
film(this is
the film used my most wedding photographers) , f707 and walgreens
combination give smae or better results than 35 mm and NPs
combination. I have trid Walgreens only once, I hope they keep the
same quality always.
3. Ofoto is not badd too: better than Walmart, but not as good as
Walgreens.
4. Printing using HP Photosmart 1100 is not close to any of the
above, may
be close to Walmart.
Unless you are printing a lot I have found I spend less money
sending photos to ofoto. If the volume is low I find the quality
from inkjet prints to be too variable. Some good some bad, ink
blobs here, ink dropouts and banding there. At least in the volume
I wind up doing.
Shay
My Sony F707 Gallery: http://www.shaystephens.com/portfolio.asp
I wind up doing.
Shay
found
This is not
prints.
Aladin
it on
exceptionally
photo. I
film(this is
Walgreens.
above, may
--First of all, let me tell you something about photo papers. In
general, important thing about photo papers are their technical
specification, not who makeks them or the printer brand. Epson,
HP, Kodak etc. buys their papers from large paper mills.
Important specs to look for in a premium quality paper is as follow:
(1) Thickness: Minimum 9 mills for photos upto 11 x 17 inches.
Higher the paper thickness, better the paper and more expensive.
(2) Opacity: Minimum 90 %. Higher the opacity, better the paper,
more expensive the paper.
(3) ISO Brightness: Minimum 89 % for photos upto 11 x 17 inches.
Higher the brightness, better the paper and more expensive the
paper.
(4) PH level: Maximum 5.8. Lower the PH level, better the paper
and more expensive the paper.
(5) Photo life: Minimum five years. More the life, better the
paper and more expensive the paper.
(6) Water resistance: All papers are highly water resistant now.
Determining factor is the ink.
There are many other specs to consider. However, you do not want
to buy the best (highest) quality paper. You want to buy, second
one from the top of the line. The difference between the first
(top of the line) and the second from top of the line is not much.
But, you save a lot of money. You want to buy top of the line
only when you are going to enlarge your picture beyond 8.5 x 11.
Enough about technical details. I buy Epson S041272. For prices,
refer to :
http://www.nextag.com/Epson_Photo_Paper_500_SP~2339756z3znzzz1zmainz2-htm
I have a HP printer but I use Epson paper. As I mentioned earlier
in this thread, the brand of the paper or brand of the printer is
not important. The technical specs of the paper is the most
important thing in deciding which paper to buy.
By the way, when you cut the 8.5 x 11 paper in half, or whatever
size, do not forget to tell the printer the paper size. This way,
your picture will always be in the center. Select the "User
defned paper size" in the printer property box and say, 5.5 x 8.5
or whaever size of the paper you are putting in the printer.
I have been doing all of above successfully for over three years now.
I hope, this helps.
Bharat J. Sutaria
Thanks, Ann
I found this:
http://www.epson.com/pdf/rightpaper.pdf
DeeDee G.
paper.
refer to :
I hope, this helps.
Bharat J. Sutaria
Thanks, Ann
DeeDee G.
http://www.pbase.com/deedee_g/root
