David, it has been a long time since anyone paid me for writing.
I know that I tend to use long compound complex sentences.
No, I am not poking a stick at the people that bought the D30,
D60, or one of the more expensive cameras. Moore's law is at
work. In the beginning, only the CCD could be used, as CMOS
was too noisy. About 18 motnhs ago, Canon changed that by
developing a sensor with noise reduction circuitry on top of the
chip. The 18 month cycle has come around again. This time
the big step forward is the three level chip, built on a CMOS
process. This is the first actual usage of the tech, and there are
some rough edges. The ISO range is not big enough for some.
Being limited to the Sigma mount is not enough for others. Some
have said and written in published articles, that no pro would
ever show up at a shoot with a camera that says Sigma on the
front. No one is saying that there is no place for the other cameras
in this generation. The Foveon/Sigma just does what I want
my camera to do.
Yes, it has been reported that Sigma can and will change the mounts
on the lenses. I can not confirm this, as no one has actually tested
it that I know of.
Peter, you are correct in that there is very little difference between
RAW and high quality jpg's on most of todays cameras, and that the
primary advantage other than the smoother color, is the ability to
adjust the shoot settings after capture. This is because the Bayer
interpolation already introduces the errors into the files when you
are using a Bayer sensor. RAW does not stop the Bayer process.
The Foveon does not suffer from this limitation. The Bayer
process artifacts are not already present. You can actually use
and gain the benefit from the much greater amount of information
present in the RAW files. You are also correct in that for web
usage, a lot of that information is useless. If the web was my
main target, other than the obvious lens limits, the G1 I already
own is very good. For the lowest common usage these files will
be used for, I guess JPG would be fine. I print at least an 8x10
of all of my best shots. I often print multiple copies. Serious
reproduction of the images is where the full information is needed.
I will conceed that you and several other seem to be very worried
about the file size. Maybe they should add a jpg mode for those
people that would use it. I am not one of them. 2000$ camera,
900$ lens, and I am not worried about having to purchase a
300$ storage device to use it.
The resolution of the present D60 files being displayed is impressive.
The smoothness of crops blow way up is also. I am not knocking
the D60. I want a Foveon based camera, because it matches
my usage perfectly. If jpg, high ISO, Canon, Nikon, or even
Tamron lenses all are part of your needs, then this camera will
not be for you. Other than that, we do not know yet!
