1) All this "Green cast" talk about the SD14, is this a non-issue if
I use eg. LR2 with a preset, or is it necessary to correct it picture
by picture (depending on the lighting)? I'll only shoot RAW, so JPGs
is not an issue.
I have never had an issue with the SD14 producing a green "cast" -
but when the very, very first models came out before ACR was updated,
there was a green noise pattern. This was firmly shoved in the
history books when ACR was updated, and it wasn't an issue with SPP.
(Can't comment on 18-200 non OS, I have the OS one).
3) Some of the used SD9s and SD19s are bundled with the
18-55 DC
18-50 ??
55-200 DC
28-105/2,8-4,0
Which of these are 'decent' to begin with, and how do they compare to
the 18-200?
On the whole the SD9s are bundled with older technology lenses (mine
came with the Aspherical 24-70 f3.5-5.6 for example). They're not
close to the 18-200's performance; I've used the current 18-50
f3.5-5.6 DC HSM and the older model that was provided with my SD10
twin-lens kit, and they're like chalk and cheese, the older lens has
quite a lot of fringing. It's a cheap kit lens, I don't expect much,
but the current HSM model is much improved.
f2.8 is a different beast entirely.
It's ages since I've used the kit 55-200, but again, I think the
18-200 will be superior.
4) Is there a comprehensive and fair review of the SD14 to be found
somewhere?
Heh. Fair is a funny word.
5) I've read mixed things about the viewfinder in the SD14 and the
SD9. According to
http://www.neocamera.com/feature_viewfinder_sizes.php?order=size
the SD14 OVF is quite small. What size is the SD9 OVF, and does it
use a prism too?
Both use prisms; the SD14 is a 98% coverage, the SD9/10 are 105%
coverage with a "sports finder" greyed out area. The SD14's
viewfinder is not that much of a backwards step but a lot of people
missed the sports finder.
I really think that if you can afford it, the SD14 and 18-200 OS is a
fantastic all-purpose kit. The SD14's batteries are less of a fiddle
to charge, it uses UDMA cards (150x), the built in small flash is
quite useful, you've got a PC sync socket, the ability to fire out
JPEG files if you just want to get some snaps for web use - and it
feels like a slightly denser, solid camera. Also the shutter noise on
the SD14 is something else.
