I noticed a lot of people here saying get the largest drive you can
afford. Something you should know is that the bigger capacity drives
are more prone to fail reading data. In fact most drives are now
using ECC (error checking & correcting) functions all the time. Not
to say you shouldn't get a high capacity drive, but if I were you, I
would:
- get all your hard drives in a mirrored (redundant) configuration,
so if one drive fails, you don't lose everything
- or use a backup service like amazon S3 & jungledisk
- use firewire 800
- or if you have a PCI Express slot consider an external drive cage
using using a SATA bus extender. This way, you can have one cage
which takes maybe 5 standard drives, which are as cheap as chips.
You can plug them in, configure them as say a mirror or RAID
configuration for safety, and get speeds possibly faster than if you
were running it on your own local internal hard drive (assuming you
get some speedy 7200 or 10,000 rpm disks).
I use the Sonnet cage, which is nice, but I wouldn't recommend them,
because the mac drivers are crumby. But there are many others to
choose from. Whenever I fill a disk up, I pop it out & pop another
one in. I can keep the hard drive as its own archive if I like.
If you do go for the standard external HDD type - go firewire & Lacie.
Nick.
