Chris, I was using the tripod and the 420. I put it outside to
cool in a sealed bag a while before using it. All was well for 36
shots, but then while setting up the 37th, it just quit. The lens
did not retract all the way, but it did retract part way. It acted
like they do when they go into sleep mode, only it wasn't
responding to being turned on and off, or to the display mode
either. It worked again when it warmed back up, but the file
transfers were very very slow. I don't know if this is a microdrive
issue or not. I changed the bios setting from allow DMA for USB
yesterday because of a setup conflict, and that may explain the
slow transfer rates. Anyway, it is working fine again, and it is
under factory warranty until June, and under replacement or
repair till next Febuary thru the store. If it is a problem, I have
time to get it fixed.
Snow pics are hard to get right! I got the exposures right
today, but I still haven't got it quite right. They look like black
and white images. Now, that is most of the color out there,
but even the greens of the cedars and pines did not come
thru very well. Even using the flash helped very little. The only
image with good color in it is one with the flag backed by the
tops of snow covered trees. The image looks black and white,
and looks like the flag was painted on. It may have been the
light, as the clouds never moved off today, and the sky was
almost as white as the snow. Anyway, I am going to take it out
again tomorrow, and I will try the under the jacket idea, and
shoot hand held.
to prevent this I wear the G1 with the neck strap under my jacket
and put it back under the jacket directly after shooting ... so far
this worked fine.
And I don't get in trouble with condensation.
Greetings from Germany
Chris
As with any electronic, when it's a cold, the internal circuit of
the battery is having a hard time making contact, so as it warm up,
the current flow much easier. For example when you start your car
in the cold. It doesnt start as good as it compare in the summer
time.
Tin
Once the camera warmed back up, it started working fine
again. I don't know if it was the cold, the battery in the
cold.
