Does CS1 support .DNG? I read somewhere someone mentioned about converting RAW's to .DNG (I guess DNG stands for Digital Negative Graphic, and it's Adobe format?)Your menthod shows PS CS 2. Can I do the same thing on CS (1)?
I opened Camera Raw.8bi file in Hex Editor and changed the values manually.I had the same problem when i edited the RAW file & replaced 30D by
20D did u edit he file manualy or by script?
I replaced 1D Mark II with 30D. Should I replace 20D with 30D?I had the same issue until I:
1: Replaced Mark II rather than 20D
How do I do that?2: Cleared the cash for camera raw
No, You did the same as me then.I replaced 1D Mark II with 30D. Should I replace 20D with 30D?I had the same issue until I:
I did it through bridge. Tools/Cache/Purge central cacheHow do I do that?2: Cleared the cash for camera raw
Bakul Vyas
Canon EOS 1D Mark II N was included in Camera Raw 3.3. That file is compatible with CS 2 only. Not with CS 1.Sorry - "Canon EOS 1D Mark II N" is the one to replace. Got to
learn to read more carefully...
