Mushy,You don't really need to use iso 100/200. 400 is fine. If you don't
like the noise, the load the pictures into NeatImage and that
should get rid of most if not all the noise, even if you use iso
1600.
1600.
Thanks for that excellent advice!! I nearly didn't post the pics
because of the noise but just goes to show with this site that if
you don't have a go there is a big chance you will miss out....
I read your post downloaded the software and this is what I got.
First photo (cloud bubbles) was at ISO 100 the others were at ISO
800 not 400 as I stated previously. Noticed my mistake when the
info was shown for each image.
BEFORE
AFTER
Following can be checked against FIRST POST
AFTER
AFTER
AFTER
Wow! Big difference
Learnt two things - software available to reduce noice and it is
worth posting your photo's (regardless) to get the advice.
Thanks again
Paul ;O)
I haven't ventured into raw mode yet, went to a digital w/shop and on advice from a pro he suggested I get more familiar with the camera first. So that's where I'm at :O)Glad I could help. Did you shoot these in RAW mode? If so, you can
adjust all sorts of things such as white balance AFTER the shot has
been taken.
Have to be honest haven't really got my head around the photoshop elements had a bit of a play but nothing like the results I just got on the NeatImage software, that is a keeper.Also, there are some really good sharpening tools out
there also or you can try "Unsharp mask" in photoshop. Nearly every
professional picture you see posted are already altered (post
processed) in some way before they are posted. Also, the lens used
makes a BIG difference (more than you think).
Put some money aside for photographer personal trainer but may have to use some of it towards the above lense have seen so many good posts on it... $180 auThe cheap 50mm 1.8
canon lens is one of the sharpest lenses you can buy without
spending thousands of pounds. Great for portraits.
I have to ask if you had the choice which would you take??Hi,
The differences between the 1.4 and 1.8 are not very noticable in
terms of quality.
Secondly, I wouldn't worry too much about second hand lenses. Most
are fine as even dust/ minor scratches on the lens is not really
noticable in amature photography.
Paul.
terms of quality.
Paul.
Taken in Armadale, Western AustraliaHi,
Mamatus clouds, wow... I've never seen anything like that north of
the equator, here in New York.
Nice shots!
Anthony
http://www.congiano.com
