technoid
Moiré is spatial frequency aliasing. As such it is most sensitive when using high quality lens, precisely focused, minimal diffraction (low F-stop), either red or, slightly worse, blue patterns, together with a pattern which repeats closely to the associated pixel spacing. Blue is the most vulnerable since it has the shortest wavelength and hence the smallest diffraction (Airy disk diameter).
Raw conversion algorithms can do a decent job with some types of moiré, especially pattern induced, localized color artifacts, but not others such as low frequency moire which can't be distinguished from an actual luminance ripple at the alias frequency.
Low pass filters, which are on most cameras do a reasonable job of mitigating this at the cost of lower resolution but by forcing a lower bound on resolution and decreasing resolution in general.
I recently, in looking at the tradeoffs and going through a quick bit of math chose the 50MP 5DSR. First new digital in quite a while. Last one was a 1DsIII.
I would occasionally have issues with moiré on repeating patterns or fabric and an F-stop of F8 or less, rarely with F11.
Because of the smaller pixel spacing on the 5DSR I expect moiré sensitivity to drop about 1 F-stop and that seems to have been the case though it is quite early.
So, with that as background, are there test charts specifically for quantifying moiré in the blue or red range where digital imaging is most sensitive to aliasing due to the 2x pixel spacing?
Also, almost all aliasing could be eliminated by using a raw converter that takes two images, one of which is very slightly out of focus. At least for stationary, aligned shots.
EtoA; I haven't seen a raw converter with that option but it would be relatively simple.
