When I plot a set of photon transfer curves for the Sony alpha 7S, I get this:
The horizontal axis is the mean value -- aka the mu -- in a 100x800 pixel region of interest (ROI). The axis is a log scale in stops below full scale. The Sony has at best a 13-bit ADC. The horizontal axis is the standard deviation -- aka the sigma-- in the ROI. The axis is also a log scale in stops below full scale. I've only plotted the whole-stop ISOs for clarity. You can see the bottoms of the ISO 3200 and ISO 1600 curves mash together because the a7S changes conversion gain at the ISO 1600 to ISO 2000 transition.
The ISO 100 and ISO 200 curves have an odd "ringing" at low mu's. Let's look a little closer:
Normally, I have the analysis program throw out low SNR data points, so I don't see much of this. I told it not to do that for these curves. The a7S, like the other alpha 7 cameras, does not truncate the low-signal histogram. I've seen this effect in other cameras, but not in all cameras.
What causes the "ringing" in the measured sigmas? And why does it occur only at low ISO?
I have a guess, but it's only a guess, and I'd appreciate any input from you all. My guess is that when the read noise is small compared the the LSB voltage spacing of the ADC, small variations in mean values can cause the read noise to be quantized differently.
What's your opinion?
Thanks,
Jim
blog.kasson.com
Thanks,
Jim
the last word the last word - Photography meets digital computer technology. Photography wins -- most of the time.
blog.kasson.com
