a used canon APSC for 5 years and switched this year to Nikon D610. I am really happy - the D610 is a amazing masterpiece for that money. before i bought I read a lot on this forum and was aware of a AF system that is maybe not so top (compared to D800 or D7100 ) and a read a lot about skintones. Reading some posts here, I got the opinion, that Nikon skintones are not as good as Canon skintones. Now I was with some friends in Croatia. Friend of mine has a 5DMkII with a 85 f1.2L and I used D610 with 70-200 f4. I have to say, that I am fully happy with the skintones. Also AF is very good.
this are pictures that were taken without special arrangement and it was not the intention to make a comparision. this idea popped up, when i got the pictures from my friend and found out, that there is the same situation and the pictures are similar. RAW and little bit of contrast in LR.
Waht is your opinion about skintones?
D610
5D MKII
I think those are realistic. I have no problem with accurate and even pleasing skintones with my D300.
I don't do a lot of portraits, but I do shoot a lot in harsh lighting with a wide range of skintoness, usually in the same images.
The images reflect the skintones well and accurately, the results therefore even after adjusting for the harsh direct sunlight, obviously uncontrolled.
I have a calibrated monitor, I process RAW, usually starting the conversion with Capture One 7 and if not ACDsee Pro 7.
The images I print come out as per screen. I printed a few recently, as per usual, with a variety of skintones and the printed image rendered accurately and actually , very pleasingly, if I may say so. The person I did them for loved them.
My own opinion is that a good RAW software and a good color profile in that software (for the day) is the key to accurate color and tones.
I am not even very experienced in photography, amateur only,. so if I can do it...
An aside - the thing about JPEG is, there are baked in settings and color profile. So when they are processed, one is starting with the baked in white balance, color settings, that may simply not be applicable to the situation on the day/ event. There is no way the camera engineers can put in one setting (even within each WB parameter) or color setting that accurately reflects / interprets the variety lighting and colors that each day and event has.
So, JPEG is the worst possible place to start when one is after any color accuracy, including skintones.
But, if one gets things right in JPEG, good on you.
Personally, aside from immediately sending a news photo / event photo off to an editor asap (or as a backup in the second card slot if you have one), I just don't see why anyone shoots JPEG, after spending thousands on a DSLR and lenses.
But we each choose differently. That is what makes the world after all.
Cheers.
Wishing You Good Light.
