Dr hatem Ayman
Well-known member
- Messages
- 137
- Reaction score
- 41
Any ideas. I dont mind MF or manual exposure
Most semi-fisheye adapters are basically terrible optics: not true fisheye projections, but just moderate wide-angle converters with terrible barrel distortion. I have a bunch and I don't use them. Well, I guess I've occasionally used one on a camcorder or a webcam.... Then again, I've used more $4 door peepholes on webcams. ;-)Any ideas. I dont mind MF or manual exposure
I recently obtained a well-worn copy of the legendary 16mm Rokkor fisheye and can whole-heartedly recommend it as a fantastic match for the A7.Most semi-fisheye adapters are basically terrible optics: not true fisheye projections, but just moderate wide-angle converters with terrible barrel distortion. I have a bunch and I don't use them. Well, I guess I've occasionally used one on a camcorder or a webcam.... Then again, I've used more $4 door peepholes on webcams. ;-)Any ideas. I dont mind MF or manual exposure
The old Spiratone/Accura fisheye adapter -- the one that screws into the front of a lens but has its own aperture control -- is actually not bad stopped down somewhat on an appropriate lens. It is a little touchy about what lens is appropriate. Basically, it was designed to work on a fast 50 to give a circular fisheye image on full frame. I would not spend as much on this as I did when I got mine, but I've seen these go for under $40 on eBay, and for that price it would be one of the better choices. Just be careful that it has the right adapter to screw-into the filter ring on the base lens you want to use it with, because the adapters are not standard rings.
Probably the best full-frame (as opposed to circle in the middle of the frame) fisheye for an A7/A7R would be one of the old 15-17mm fisheyes. My understanding is that IQ of some of those is excellent, but they can be hard to find for less than $200, which is a little steep for such a special-purpose lens. I haven't tried one of those since the 1970s when the 16mm Minolta was really pricey, but it was quite impressive on film back then.
There also are modern high-end fisheye converters that produce very good IQ and work well with lots of base lenses. The 185-degree Raynox DCR-CF185PRO in particular really delivers. However, it cost me about $350 new and is heavy enough to be scary screwed-into the front of most lenses -- heavy enough to potentially strip autofocus drive gears, etc.
Zenitar 16 fisheye lens worked well on my Pentax, not sure how good they would be the A7Any ideas. I dont mind MF or manual exposure
Hi Prof,Probably the best full-frame (as opposed to circle in the middle of the frame) fisheye for an A7/A7R would be one of the old 15-17mm fisheyes. My understanding is that IQ of some of those is excellent, but they can be hard to find for less than $200, which is a little steep for such a special-purpose lens. I haven't tried one of those since the 1970s when the 16mm Minolta was really pricey, but it was quite impressive on film back then.
It has never been true. The prices just got worseI'd be very happy, if I could buy a decent Minolta MD 16mm fisheye lens for $200. In my region (ebay.de) a clean MD 16mm/f2.8 goes for 550 euros (USD $760 :-O ).
With the arrival of the A7, the guys owning nice collections of old lenses are becoming rich.
The myth of "buy-a-decent-old-lens-dirt-cheap" is over :-(
i, too, am looking for a fisheye to pair with the A7. i am looking at the samyang 8/3.5 adapted from canon. would that work? its a fairly large combo though.Any ideas. I dont mind MF or manual exposure
Sadly, you're right: these lenses have gotten much more consistently expensive.It has never been true. The prices just got worseI'd be very happy, if I could buy a decent Minolta MD 16mm fisheye lens for $200. In my region (ebay.de) a clean MD 16mm/f2.8 goes for 550 euros (USD $760 :-O ).
I mean, I don'\t remember finding a nice MD 58mm 1.2 for less than 350 Euro since years.
Same goes for the 16 mm, which is basically the only MD/MC lens I don't have due to the price.
The only good deal I've done was a mint AR 57 mm 1.2 for 50 euro, which sells for about 300![]()
Same here, though for $200 I might have still bought it for my XD7 (here in Europe I've never seen it for such a low price!).I have had several opportunities over the last few years to purchase the 16mm f/2.8 MC for around $200, but didn't see the point for my APS-C NEX.
The 16mm full-frame fisheyes (e.g., Minolta 16mm f/2.8 MC) give a rectangular image that is 180 degrees corner to corner on a full-frame sensor. That's what you want, right?Well thanx for all the answers but I dont want an adapter and I dont want a full fisheye for the a7 but a semi fisheye. Does the samsung give semifisheye images or full circles ?
Hi Prof,
Miki
Samyang 14 is a rectilinear lens. For FF fisheye, Sigma 15 or Minolta/Sony 16 would be good choices.Any final word on which to choose ?
Are you reading the posts here?Thanx for the 8mm/f2.8 tip/ Here is an interesting review. I think I will buy this one. I like the fisheye effect contrary to the majority, it makes you fell photography is art
http://www.dpreview.com/forums/post/50823245
