dark goob
Leading Member
In the E-M1 there is a weird menu option called "Release Lag-Time" with two options: [Normal] (default) and [Short]. When you select Short, an audible click can be heard inside the camera. Then the shutter release sound and vibration seems to become reduced (although in either case it's still much louder and feels like more vibration than the E-M5's whisper-quiet shutter).
Why do they even have this option? What exactly is it doing? What's with the click sound when you engage it? Why does it make the shutter sound less like a tiny mousetrap when the picture is taken? What is it doing to reduce lag precisely, and why does that involve a greater drain on battery life, according to the manual?
The manual states:
If [Short] is selected, the time lag between fully pressing the shutter button and the shot being taken can be shortened.*
* This will shorten the battery life. Also make sure that the camera is not subject to sharp impacts while in use. Such impacts may cause the monitor to stop displaying subjects. If this happens, turn the power off and on again.
Oh and, what's with this avoid "sharp impacts" warning? Don't you typically want to avoid sharp impacts to your camera, no matter what the settings are?
Note: I wish Olympus had a full-length printed manual with their flagship camera, and not just a "basic" one with the rest online. Frankly I expect at least a full-length user manual out of a $1400 box.
The manual states:
