xtoph wrote:
LEROY PAUL wrote:
Should i get a DSLR or a mirrorless camera for street photography ? I'm struggle between this 2 type of camera . Which really suit for street photography ? I'm still comparing Nikon d7100 for DSLR and Olympus ep-5 and Panasonic GX7 for mirrorless . Please give me some advise .
i haven't had a chance to use the new crop of mirrorless cameras personally, though i have used their predecessors and i've taken note of some of the early reviews. they appear to be excellent cameras, and the oly in particular is well known for its face tracking af, useful in street, and proven sensor. the new high res vf for it is an additional cost, of course.
in my experience, there isn't a huge difference between shooting street with a smallish dslr (like the excellent nikon) and a mirrorless camera. all other things being equal, though, there is a little bit of difference. the smaller cameras are generally less intimidating to people. your attitude as you use them will probably matter more though.
the sensor and af on the nikon will be a bit better than the mirrorless, and the af in particular might help you get some difficult shots. more importantly, the good quality optical vf is a very strong tool to use to make the most of your opportunities. the nikon is the safe choice--you can't really go wrong with it.
but in the end i would choose based on what lens or lenses you want to use. the pany 14/2.5 or oly 17/1.8 are probably the best choices currently for mirrorless street. either of those will keep the size advantage of the system and deliver fine results. with the nikon, you probably want the 28/1.8 (though that is even nicer on full frame) to retain speed, though at a slightly longer effective angle. this is the difficulty with dslr systems: the lenses still aren't completely fleshed out for crop sensors. so unless you are interested in bumping up to a d600... (bear in mind that you may save some money by getting to use cheaper lenses with it; e.g., on a d600, you can use the inexpensive 28/1.8, while to get closer to that performance on the d7100, you would need the larger and more expensive 24/1.4... )
so that may not make your decision for you, but i hope it helps. the new mirrorless options do finally offer good direct controls, so for the first time, they come close to real parity with bigger cameras.
if you still can't decide, ask yourself which setup you will be happier bringing over your shoulder everywhere you go. if you are less likely to bring the larger system with you, then unless you also need to use it to shoot sports, go with the smaller mirrorless camera.
have fun
