I have never quite understood how larger formats are supposed to allow for higher resolution, but I have now realized a good way to phrase my question so I might get good answers.
As far as I understand it, the following points are generally accepted to be true when comparing sensors with identical resolution:
Will equivalent photos taken at the same resolution, with the same FOV and DOF have different amounts of diffraction?
My intuition says that they will have the same amount of diffraction. If that is correct, I see one alternative aspect where larger formats may yield higher resolution: Lens sharpness.
Once more, it is my understanding that:
Will Lenses for larger formats generally be sharper relative to sensors size than lenses for smaller sensors?
My intuition says no, there won't be much of a difference. And if my intuition is correct, then I am really wondering where the supposed superior resolution for larger formats is coming from. I appreciate any answers that make this clear to me!
- All else being equal, smaller sensors will suffer more from difraction when using a given f-stop due to smaller pixels.
- All else being equal, smaller sensors have more DOF at a given f-stop.
- Lenses for smaller sensors are easier to make sharper than lenses for larger sensors...
- ... But because larger sensors (having same resolution) will have larger pixels, this effect is again reduced
