Muizen -Belgium
Forum Enthusiast
So far I use Multi as focus area.
I feel that possibly due to the fact that the green focusing outline box in Multi is large (I think far too large) it is almost close to impossible to focus on an eye when shooting a portrait.
Also sometimes focus does not hit the selected object but pick's out something totally different.
It is very strange in my opinion that In Multi you do have to guess where the focus area is since there is no permanent focus outline, like there is in Center and in Flex. Spot.
Questions:
1) I would like to have a permanent focus outline in Multi. Is there a way to produce such a focus outline for Multi? This would make it possible to know on what part of the scene I am going to focus!
2) If not I would then switch to using Center which does show a permanent outline which also seems to be smaller than the one that shows up in Multi when focusing, or I could use Flex. Point, which has an even smaller permanent focus outline? What do you recommend?
3) Now and then i suddenly get two or three green focus areas on the LCD when focusing in Multi. How can I avoid this?
4) Is there a way to reduce the size of the permanent focus outline in Center and or in Flex Point to enable more precise targeting of the focus?
The focusing function of the RX1 is its "Achilles heal", for me an almost permanent source of irritation!
Harry
Questions:
Harry
