Dustinash wrote:
Anyone else have this problem? Anyone even know if you can use a lubricant on it? Very dissapointing i sent it in to Sony to be fixed and they sent it back now even acknowledging the problem
Are you sure there was no sugary drink drop spilled over that switch?I have the same problem, i just bought this camera 2 months ago, i'm a such poor guy, i saved so long time to buy it... I'm so sad, damn if Sony don't repair me that i gonna kill myself :-x
Yesterday everything was ok, and now i don't know why this switch don't move like before it's just pain in ass to push it
Anyone have a clue about the origin of this issue ?
Maybe, there are a chance, that it will be recover with time ?:-(
Mine is like yours, usually sticky, but sometimes worse than others. It does not seem to be weather related, i.e. temperature or humidity. It does not seem to be getting any worse, but it certainly is not the way it should be. The feel is like two pieces of plastic that have been galled with wear rubbing together.Well, this looks like a more than rare issue. Mine is also hard to turn on & off too, but it's variable. Some days, it's not as difficult as others. My plan is to just live with it unless it get to where I can't turn it on & off.
Too bad Sony doesn't have better support for something like this. If they could fix it, it'd probably cost $300
AEH
http://aehass.zenfolio.com/
http://aehass.zenfolio.com/blog
Question: What do you do all week?
Answer: Mon to Fri. Nothing, Sat & Sun I rest!
You have to read more carefully. It is claimed to be 'weather sealed', not 'water resistant'. And nobody knows what 'weather sealed' really means... but it offers a clue regarding the stiff power switch. Maybe there's an O-ring or similar barrier under there intended to keep stuff out of the interior of the camera, and maybe that barrier causes additional friction.They have alreay told me that the A77 is not water resistant, and that's with all that advertising and writeups and brochures...
Thank you to share your experience, i guess you found out the origin, yesterday night i was in party there are lot of beers of course, i didn't drink, but maybe a friend who i ask to shoot me, have some dirty finger with sugar or anything...Are you sure there was no sugary drink drop spilled over that switch?I have the same problem, i just bought this camera 2 months ago, i'm a such poor guy, i saved so long time to buy it... I'm so sad, damn if Sony don't repair me that i gonna kill myself :-x
I had the same problem with the (different) switch on my A700. Caused by some party visitor throwing his bear around. A real pain the next day, to free it to a usable level.
Bart
Hah, just re-read this LOL. Quite a sight, I could tell you! And the pain to free it...Are you sure there was no sugary drink drop spilled over that switch?
Bart
If floss by itself does not work, try dampening it with iso-propyl alcohol. That may cause the foreign matter to transfer to the floss.
I did free an on/off slide switch with a short spray of WD40 on a Minolta film camera, which has been fine ever since, but try everything else first.
Im aware of a great deal of comment, both for and against, about this subject on the internet. In my experience, and that of some colleagues with considerable electronic equipment maintenance experience, that isn't the case. The theory is that the contact surface area is reduced by the silicone deposit, but that increases the current density, which tends to burn off the dirt which is causing the problem. One colleague, with a problem of bad contact on multi-contact switches, actually used silicone grease dissolved in WD40, painted on with a fine brush. It worked very well.Just a small point Ian, WD40 is silicon based and is a good insulator. It shouldn't be used on electrical contacts. there are proper contact cleaniing/lubricating sprays around for this.If floss by itself does not work, try dampening it with iso-propyl alcohol. That may cause the foreign matter to transfer to the floss.
Ian
