RussAdams
Leading Member
I'm not a video guy. I mostly take stills and will likely continue to do so.
I've ordered an A77 in Dublin, Ireland, which should arrive next Tuesday. But, I'm a Yank, and will be returning to the US sometime next year.
I've read the spec that says the European version will come with video set to PAL and not NTSC. And the warning from abstrusedali (in my thread saying I ordered one: http://forums.dpreview.com/forums/read.asp?forum=1037&message=39394730 ) that the A77 won't be switchable between the two.
And I've tried to figure out what that means from a usability standpoint.
DPReview says:
Image sizes (Video)
NTSC :
• AVCHD: 1920 x 1080 (60p/ 28Mbps/ PS, 60i/ 24Mbps/ FX, 60i/ 17Mbps/ FH, 24p/ 24Mbps/ FX, 24p/ 17Mbps/ FH)
• MP4: 1440 x 1080 (30fps/ 12Mbps), VGA: 640 x 480 (30fps/ 3Mbps)
PAL :
• 1920 x 1080 (50p/ 28Mbps/ PS, 50i/ 24Mbps/ FX, 50i/ 17Mbps/ FH, 25p/ 24Mbps/ FX, 25p/ 17Mbps/ FH)
• MP4: 1440 x 1080 (25fps/ 12M), VGA: 640 x 480 (25fps/ 3M)
File formats (Movie)
• AVCHD 2.0 (Progressive) / MP4
• MPEG-4 AVC (H.264)
Why does PAL record MP4's in 25fps and NTSC record MP4's in 30fps? Why should they be different? I thought MP4 was a computer standard, not a TV standard?
What PRACTICAL effect does that have on me?
Do PAL AVCHD and/or MP4 videos NOT play on NTSC systems or computers and vice versa?
If the camera records in PAL, I'm guessing that means I won't be able to plug it into an NTSC TV and play back the video using the camera. What about Stills? I'm guessing I won't be able to play back stills on TV's back in the States either. I've never done this with any camera. Should I care?
Confused...
I've poked around and can't come up with meaningful answers.
Advice or help would be greatly appreciated!
Russ
DPReview says:
Image sizes (Video)
NTSC :
PAL :
Confused...
Russ
