Ernie Misner
What are the downsides to doing the Win 11 upgrade from Win 10? Programs don't have to be reinstalled unless you change the motherboard, is that right? Thanks.
This is a very simple upgrade Ernie. Most everything will continue to work. If you launch programs from the desktop you will have nothing to do. If you use the start menu you will probably want to adjust it after the upgrade. Possibly you will want to reconfigure the taskbar to have the start button on the left side rather than the default center.What are the downsides to doing the Win 11 upgrade from Win 10? Programs don't have to be reinstalled unless you change the motherboard, is that right? Thanks.
You may need to reactivate some programs depending on the specific software you have installed, but they should all work as before without having to reinstall them.What are the downsides to doing the Win 11 upgrade from Win 10? Programs don't have to be reinstalled unless you change the motherboard, is that right? Thanks.
Programs usually survive a 10 to 11 upgrade without issues. But it's not guaranteed.What are the downsides to doing the Win 11 upgrade from Win 10? Programs don't have to be reinstalled unless you change the motherboard, is that right? Thanks.
What method did you use to update your 15 year old i7-2600 to Win11?I didn't have any downsides. Everything still works great. All my programs and data are intact (though I did backup my data first, which I do regularly anyway, as everyone does, I hope). And I have a 15 year old i7-2600. I did make a few UI adjustments afterwards to make it closer to how 10 looked, like moving the start button back to the left and other things like that.
I used FlyOOBE. If I keep it in the center, it keeps moving, as I open and close more programs, and that is annoying. And I always know exactly where my start menu and shortcuts are located.I upgraded my wifes unsupported W10 dell laptop to windows 11 using flyoobe and it never had any issues. I am guessing your system is a supported system? if so everything will work as advertised. Keep the "start menu" in the center as it speeds up work flow. having to just go down instead of across and down to the corner to get to the menu.
I have yet to encounter any software that worked on 10 that didn't on 11. It's the same OS under the hood in reality.
FlyOOBE. Super simple.What method did you use to update your 15 year old i7-2600 to Win11?I didn't have any downsides. Everything still works great. All my programs and data are intact (though I did backup my data first, which I do regularly anyway, as everyone does, I hope). And I have a 15 year old i7-2600. I did make a few UI adjustments afterwards to make it closer to how 10 looked, like moving the start button back to the left and other things like that.
Many thanks to you and to all who replied about my Win 11 question. Much appreciated.I had an issue with an old driver (Win 10 didn't have core isolation enabled) but that was easily resolved.
In a side note, I always had found the new start menu introduced in Windows 10 as being awkward but so I switched to Open-Shell and after 10 minutes of configuration I really liked it. Much quicker to get at what you want.
Thank you kindly, Morris and to all who have responded. My computer is a home built version, and currently, MS says that the hardware is not supported for Win 11. I'll be looking into that more. Thanks again.This is a very simple upgrade Ernie. Most everything will continue to work. If you launch programs from the desktop you will have nothing to do. If you use the start menu you will probably want to adjust it after the upgrade. Possibly you will want to reconfigure the taskbar to have the start button on the left side rather than the default center.What are the downsides to doing the Win 11 upgrade from Win 10? Programs don't have to be reinstalled unless you change the motherboard, is that right? Thanks.
So head over to Windows Upgrade in settings and kick off the upgrade. Then enjoy a cup of coffee and return to answer a few questions. Then let the system complete the upgrade. You might want a second cup of coffee or to occupy your time another way. If you have a high end system total time can be as little as 15 minutes and with lesser hardware allow for an hour.
Morris
