Erik Kaffehr
Most MFD cameras will alias images, but it seems that aliasing matters little to many photographers. Here I explain how it works.
Let's start with an example:
This was not shot on medium format, it was shot using a Voigtlander 65/2 APO Lanthar on a Sony A7rIV. What we see is that image on the left has a lot of color aliasing while the image on the right has very little. The images should be viewed at actual pixels, see the link below.
The difference between the two images is the aperture used. The lens used here is sharpest at f/2.8 or f/4. Shooting at f/11 we see significant diffraction that acts as an OLP (Optical Low Pass) filter.
To best understand the difference, we can look at MTF plots for both.
The blue line is the MTF at f/4 and the red line is MTF at f/11.
Now, note the vertical line at 3168 cy/PH. That line is the Nyquist limit. Any signal above Nyquist is unresolved signal. According to sampling theory, those signals will be folded back to low frequency artifacts, also called aliases.
Something like this, note that there is a significant area under the folded back blue line, not so much under the red line.
Now, most digital cameras use a Bayer filter array in front of the sensor that detect color information.
This shows the G and G2 channels. Note the aliases 1round 130 lp/mm. Note that the G1 and G2 aliases are pretty near invented.
It is more visible here.
What we can see here is that undersampled detail is turned into aliases and these aliases show up differently for different pixel positions.
If we include red and blue pixels, we get a color pattern, known as moiré.
Now, how does this show in an image?
Image shot on Phase One P45+ (6.8 micron pixel pitch 55% area fill factor)
We have extensive aliasing artifacts on the reeds.
The images shot here were shot on:
A) Sony A7rII with a sharp lens 4.5 microns
B) Sony A7rII with a good quality standard zoom 4.5 microns
C) Sony A7II with the sharplens, Sony A7II is 24 MP with an OLP filter 6 microns
D) Sony A7rIV, 61 MP without OLP filter 3.8 microns
E) Phase One P45+, 39 MP, low fill factor, 6.8 micron pixels
All viewers place D first and E last. All viewers preferred B to A
Why do I often see aliasing artifacts in my images?
Erik
Erik Kaffehr
Website: http://echophoto.dnsalias.net
Magic tends to disappear in controlled experiments…
Gallery: http://echophoto.smugmug.com
Articles: http://echophoto.dnsalias.net/ekr/index.php/photoarticles
- Most cameras use 'Bayer' pattern
- Some Fujifilm cameras use a pattern called X-TRANS
- Foveon cameras don't use color filter array, but use a stacked sensor design and basing color information from light absorbtion in the layers affecting different wavelengths differently.
- I often use good lenses with medium apertures.
- I try to focus accurately.
- And I almost always use a tripod.
- Many of my subjects have areas with fine detail.
Erik
Erik Kaffehr
