refrigerator
Well-known member
From a mathematical perspective, won't a square (also a rectangle) and a rectangle yield the same area in a lens circle? It seems it would be more appropriate to use square frame instead of a rectangular.
If I am not mistaken, there are square sensors in some "medium format" digital backs. But those are meant to preserve the investment in medium format bodies and lenses, mostly used by professionals that shoot/shot 120 format film in the 6x6 (59mm x 59mm, aka, "2 &1/4").From a mathematical perspective, won't a square (also a rectangle)
rectangular.
rectangular.
Standard chemical process photo papers existed as 4x5, 8x10, 11x14, 16x20 etc. prior to the invention of the Rolleiflex. That is because the dominate sheet films were 4x5 and 8x10. Those aspect ratios work for uncropped enlargements or contacts with those paper sizes.For composition reasons most photos end up in rectangular formats, so
a square sensor won't be efficient.
Square sensor makes a lot of sense for the pro/avid amateur.From a mathematical perspective, won't a square (also a rectangle)
rectangular.
Yeah, and pretty much like I said in my previous posts. Perhaps someday, if sensor costs drop far enough, there will be a niche camera with one, at a low to mid-range (current dslr-wise) price, say 30mm x 30mm, 12mp. The individual receptors woud be nice size on that.The only reason that it isn't used in DSLR, must be the cost factor.
Yes but from a user perspective nobody wants square pictures. Modern TV's are getting more rectangular too.From a mathematical perspective, won't a square (also a rectangle)
rectangular.
Facts are that within the same 43,3 mm (FF) image circle, instead of a 24 x 36 mm sensor we could have a 30,6 x 30,6 mm sensor, with a 8,4% bigger area.The main problem is that people don't use square pictures, except a
few of those idiots trying to justify their square format cameras.
If you actually do the maths, you will find that a square in a circle
bounding a 4:3 format is marginally larger. The choice becomes
clearer when you cut a 4:3 picture out of it. The original 4:3 is
about 30% larger
It's more like there "were" square sensors. The sensors aren't in production any more, and you can get one of the few remaining square format backs at blowout prices ($10,000 for a bundle of a back, 500 series Blad, and the wide angle that you need because of the crop factor).If I am not mistaken, there are square sensors in some "mediumFrom a mathematical perspective, won't a square (also a rectangle)
rectangular.
Actually, they were meant to save money. Large sensors go up in price exponentially with area. The 36x36mm square backs cost about half what the 36x48 backs did.But those are meant to preserve the investment
And to get a larger sensor area than the first cropped cameras, improving the low light performance and allowing for higher resolutions.Similar to that (but more for the benefit of the manufacturer until
the advent of so-called FF, "full format") was to preserve the R&D
and decades old design of the 35mm SLR body and lenses.
A 3:2 ratio is close to the golden mean. There aren't any 2:1 ratio cameras on the market.Some would point out that the 2:1 ratio is akin to the "golden mean"
and therefore, aesthetically pleasing. Other reqtangles also have
different attributes.
Actually, 11x17 is a very common size. 8.5x11 is very close in aspect to 8x10, so no one really notices. A4 is entirely different, that's a sqrt(2) based aspect ratio system.There is a relationship between film/sensor aspect ratio, and how
much of an uncropped image you can print on a given piece of paper.
The move to inkjet printing has brought the utility of some rectangle
ratios to the fore. This is due to the inkjet photo-printer evolving
from the inkjet document printer. For example, 8.5" x 11" (A4) sized
paper. "legal size" 11"x14" paper provides the next jump up
(manufacturer's already had that carriage size, etc.
Actually they don't. Rollei actually went bankrupt, and was liquidated. Parts of their portfolio and property was bought by a variety of companies, including Samsung and Franke and Heidecke.Oh, yeah....
The square format (which I would prefer for a digital sensor, but no
can afford the digital back![]()
Is from the popularity of the Rolleiflex twin lens reflex camera in
the mid 20th century. "120 film", 59mmx59mm. That type of camera
essentially required a square negative (though 35mm and 645 adaptors
or backs where made by some). It was adopted for many clones of it,
then the Hasselblad, then its many clones. BTW: both still exist
today, new.
Actually, the 35mm square Hasselblad square back is a leftover Imacon, it was sold mainly to 645 users (where the crop factor is only 1.37 instead of 1.55 like it is on a square Blad) as a low cost alternative to 36x48mm 645 backs. They didn't sell well, so after Shriro bought Imacon and merged Hasselblad into Imacon, they discontinued the 36mm square back. They're on sale for a good price (and a bundled wide for the price of a normal) right now, but when they're gone, they're gone.To preserve their customer base, Hasselblad and others
offer digital back in the square,
The discontinued square Blad back currently at clearance price is about twice the price of a D3.and "645" (59mmx45mm) formats.
These start out at a price similar to a Nikon D3 body (Mamiya) or
more than the most spendy Canon DSLR.
Read it again, more slowly this time and with an open mind. What I said was:Um, what? Are you trying to tell me a rectangle is 30% larger fit
into a circle than a square?
That's extremely incorrect.
Facts are that a 30.6mm sensor requires 46mm of "back focus" (clear space between the rear element of the lens and the focal plane). You've got about 5mm for the shutter, and 43.3mm to accommodate the swinging SLR mirror. But lenses built for existing 35mm SLRs only have 39mm of back focus, because their frame is 24mm high, not 30.6.Facts are that within the same 43,3 mm (FF) image circle, instead ofThe main problem is that people don't use square pictures, except a
about 30% larger
8,4% bigger area.
Wrong. Some compositions call for a square cropping.Yes but from a user perspective nobody wants square pictures. ModernFrom a mathematical perspective, won't a square (also a rectangle)
rectangular.
8,4% bigger area.
